Old 01-29-2014, 10:46 PM   #1
62step
62 stepside rear end
Hey Guys, First post.
I have a 62 stepside that I am restoring, I got it from a friend who partially started restoring it. Frame sandblasted and paint, new brake lines fuel lines etc. was done. He did the 70's front end for 5 lug and rear he did 12 bolt 5 lug also. I am rebuilding this truck for a good cruiser, but I also want to be able to get on it when I hit the gas.. I'm putting a 350 motor bored .040 over with flat top pistons 041X heads and edelbrock performer intake, 274H comp cams, and probably 750 edelbrock carb.. For the trans I might go with a turbo 350.. I'm not too sure how to do a torque converter lock up switch for the 700r4's..
Back to my question..
I have 3.07 gears in the rear end now, will that be good enough gears to get up and go and do a couple burnouts in? It doesn't have posi either..
I was thinking about 3.73 maybe with the turbo 350 trans and posi. I would have to replace the whole carrier for that ratio correct?
Thanks in advance for the help and answers!
This forum is awesome.
Mike
62step is offline   Reply With Quote
Old 01-29-2014, 11:41 PM   #2
HumphreyMurdoch
HumphreyMurdoch's Avatar
Re: 62 stepside rear end
Welcome to the forum!
Glad to see another '62 on here.
Personally, I'd suggest a 3.42 or 3.55 gear. You engine should have more than enough power to set you back in your seat and still have a decent RPM for cruising on the highway.
just my .02 though
HumphreyMurdoch is offline   Reply With Quote
Old 01-29-2014, 11:42 PM   #3
HumphreyMurdoch
That's if you go TH350, if you go to an OD trans you definitely want 3.73 gears.
Old 01-30-2014, 12:14 AM   #4
Joe Pass
Joe Pass's Avatar
I'm using a 3.42 ratio and TH-350 in mine...It gives you the best of both worlds with out overdrive. 12 bolts are popular and plentiful so you could change it around if you results aren't satisfactory for not much $$$.
Joe Pass is offline   Reply With Quote
Old 01-30-2014, 12:24 AM   #5
Joe Pass
Joe Pass's Avatar
To answer you other question you can get a 3.73 ring and pinion that fits a series 3 case or a 4 case "Richmond Gear Ring and Pinion Sets 4900721" with that cam your low end will suffer a bit even with 3.42 so you might want to get a torque converter with a slightly higher stall than stock like 2000-2200 rpm. Just my opinion....
Old 01-30-2014, 02:17 AM   #6
Captainfab
60-66 Nut
Welcome to the forum Mike
With that cam, I believe you will need a bit of a stall converter, like a 2000-2200 as mentioned by Joe Pass. Those 3.07 gears will probably be ok as long as you don't go with a tall tire. L also agree that 3.42's would be a better gear with the TH350, and you won't have to change the carrier. Although you'll likely be wanting a posi before long.
If it were mw, I would go with the 700R4 and 3.73 gears. There are lots and lots and lots of threads on the 700R4 in the Engine and Drivetrain section. The torque converter lockup is fairly easy. It is the TV cable setup that can be a bit of a pain, but absolutely must be done correctly.
Old 01-30-2014, 08:10 PM   #7
62step
Thanks for the input guys! I think the recommended stall converter for the cam is like a 2500 maybe. Hopefully I can post some pics of the truck soon. It's in pieces lol
Old 01-30-2014, 08:13 PM   #8
62step
How I found it with my friend:
How it sits now, but without the bed on and fenders (lowered about 4-5"):
Old 01-31-2014, 11:16 AM   #9
kieth
kieth's Avatar
Mike
Send me the diameter of the tires and wheels on the rear end (ground to the top of the tire)
Your email address so I can email you a excel spreadsheet (cannot post it to the board)
I will send you a spreadsheet that shows you how your truck will perform as it is now and also how it would perform with most transmissions and other rear axle ratios. Your question about 3:73 can be answered with this spreadsheet. Kieth Tulsa, Ok
ps if ;you plan on changing tire sizes later let me know what it is and I can also make a spreadsheet that shows performance with those diameters. Kieth
kieth is offline   Reply With Quote
Old 02-16-2014, 11:08 PM   #10
62step
Thanks a lot! My email address is littlemlittle@gmail.com I have the truck up on jackstands right now so I can't get the dimensions.. Will tomorrow.
Old 02-17-2014, 12:39 AM   #11
AcampoDave
AcampoDave's Avatar
I say try the 3.07. Based on having had a few myself, I think you might just like it. They are a good all around rear end for a 3 spd and 15" rims. Burnouts included.
AcampoDave is offline   Reply With Quote
Old 02-17-2014, 02:51 AM   #12
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Yes, try it and drive it. You might like it.
If not, you'll then have a lot better idea what to try next.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
