Old 01-31-2014, 10:05 PM   #1
omgitsemmanuel
!964 c10 fender seal?
I have a 1964 c10 that im building but the only keeping me from putting on the front is the fender seal. From lmc that part number is 38-7449 and i cant figure out how these go, Any information helps and if you can show pictures that would be great and one last thing, for the power booster what vehicles could i take it off of and it would fit there with no or little adoption.
omgitsemmanuel is offline   Reply With Quote
Old 02-01-2014, 12:56 PM   #2
Old Bleu
Old Bleu's Avatar
Re: !964 c10 fender seal?
On my '64, that seal was attached to a metal piece with heavy staples. I will probably reattach mine with small bolts/nuts/washers. It worked fine for my radiator seals. I think some guys recreate the staples with wire if you want to be very correct. I also removed the metal piece that the seal mounts to from my fender for painting. That piece is held to the fender by 6 small metal gizmos that I don't see listed on that LMC page, but I'm sure they must sell. I ordered all my parts from Classic Truck Parts, and the snow here in GA has delayed delivery until Monday!
Old Bleu is offline   Reply With Quote
Old 02-01-2014, 02:11 PM   #3
ljackson
ljackson's Avatar
I used some galvanized electric fence wire and made staples. It turned out good for my 1st time trying. I got the idea here on the forum. I used black WS adhesive where the seals needed to be glued. I taped them in place and let them sit overnight.
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline   Reply With Quote
Old 02-02-2014, 05:20 PM   #4
omgitsemmanuel
thanks that really help
Old 02-02-2014, 05:29 PM   #5
omgitsemmanuel
ill check them hopefully and if i call they should be able to tell me if they have them.
Old 02-03-2014, 07:52 AM   #6
ljackson
ljackson's Avatar
I also found this today. It's out of an assembly manual. Have you had a chance to get some manuals? These mentioned in the threads below helped me a lot. Good luck with your truck.
http://67-72chevytrucks.com/vboard/s...d.php?t=564999
http://67-72chevytrucks.com/vboard/s...d.php?t=522765
Old 02-03-2014, 10:36 AM   #7
omgitsemmanuel
Thanks for the info. I can't find my plate have no idea where it went so going to have to make something but I have and idea now on what I can do.
Old 02-03-2014, 11:29 AM   #8
1963c-10
1963c-10's Avatar
Anybody know where to find the finish panel retainers?
1964 Short bed trailer
Old 02-03-2014, 11:34 AM   #9
Old Bleu
Old Bleu's Avatar
I ordered mine from classicparts.com. They and the new seals are on the big brown truck, set to be delivered today.
Old 02-03-2014, 12:18 PM   #10
1963c-10
1963c-10's Avatar
ok, thanks. Found them. Link if anybody else needs them. Part #37-663 $.95 each http://www.classicparts.com/1960-66-.../#.Uu_Bi9iYaUk
Old 02-03-2014, 06:40 PM   #11
Danny#2
Danny#2's Avatar
I need a good pair of the closing panels. The right and left sides.
Danny#2 is offline   Reply With Quote
