Custom Rear Cab Panel
Because the freight on a new rear cab is so much to Australia I am considering an alternative.
My Cab rear panel is badly damaged and stretched, Looking at the later Chev cabs that have the rear panel that is not flat I thought maybe I can use something else? I have a few Colorado Twin Cab trays laying around I thought the floor might suit as a infill panel? Any advice or opinion? Shane
Australian GM/Holden Dealer 1937 Chev Rod - LS1/4L60E 1949 Chevy 4400 Dually - 235ci/4L60E 1958 Chevy Apache Fleetside SBC/T400 |
Re: Custom Rear Cab Panel
Anyone?? Please?
Thanks Shane
![]() Join Date: Mar 2007
Shane-
To me I think your best solution might be to use flat sheet matel and have someone with an english wheel recreate the back panel of the cab. The pictures of the cabs that you are showing look totally different in shape and size and it would take more work to get something like that to work and look right. You might also get an estimate from a fab shop or body shop on a cost to replace/reshape the metal of the back cab. In the long run it may still be cheaper than your freight for a replacement cab. Good luck Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
i don't see that much damage that you'd need to replace much.
the dents on the roof can probably be pulled with a stud gun/puller maybe a little heating with a torch and quenching the ding at the beltline i'd think you could cut it out small and patch it in newer car/truck metal is a lot thinner than your cab, i'd think blending the two steel thicknesses would cause more warping. maybe i'm not seeing all the damage and i'm not a bodyman, though i hang out in a shop that does bodywork
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Unless the metal has rusted and is thin, it does not look any worse than places I had on mine. I would rather work what is there than try and get a patch panel that is right then fight the welds that it will take to install it. I would still lobby for you giving it a try to see how close you can get it. I would hate to see you cutting out a lot of the back only to find you cannot get a local replacement made that fits and looks right and end up with the expense of shipping parts from the Northland...
You would have a much better chance at making one from scratch as you would making that other one "fit". "Forcing" something to fit somewhere is much harder than making something from scratch.
Now, that being said, I am thinking you aren't even close to be needing to replace that panel. From what I see (photos can be deceiving) you aren't even close to needing to replace that panel. If you had one sitting right there, yeah replace it. But with logistics as they are, I say fix that one. If it's stretched a shrinking disc is in order, now that's cheap freight to Australia, or simply make one. http://www.youtube.com/results?searc...ng%20disc&sm=1 Here's a good one to get you started. Here's another one with a home made disc. Picture the shrinking disc as a "heat block". It only heats the high spots, so when you cool it, it is only shrinking the high spot! I am really digging that right hand steering dash, that is soo cool! I have always gotten a kick out of seeing the little hump on the firewall on the right side of mine for a steering column but I have never seen on as yours, very cool! Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
Thanks guys, I have a shrinking disc on order from a local supplier.
Can this be done over primer or does it have to be bare metal? Thanks SHane
Bare metal.
Brian
Do body work on other parts like the doors and fenders and get some more experience under your belt before doing that rear cab panel.
Just put it on the back burners and work on other parts. Then when you get to it you can take more photos and we can discuss it on the forum. Brian
Thanks Brian.
With a cab like this is it a must that the doors are on the body before cab corners etc are replaced? Shane
#11 | |
Brian
Thanks Brian,
If im doing the rear cab corner that isnt affected by the door does the door need to be on to keep the body straight or lined up or anything? Also i have the body sitting on a dolly right now should it be attached to the chassis whn fitting panels? Shane
#13 | |
ABSOLUTELY! I made a dolly out of a frame for this very reason. It uses all the cab mounts just as it will on the frame I am using. Your cab corner patch doesn't go all the way to the actual door edge at the jamb? It's always a good idea to have things hung, that is one lesson you only have to learn once. ![]() Brian ![]() ![]()
Hollister Road Co.
its a great tool for what you want to do. I have a quart / liter spray bottle with water and about 4 drops of dish soap that I spray the section with. It lets me know when its hot and adds a little slippery to the process for less galling of the metal. run the disc over an area and they spray it to cool it. don't wipe it off and run the disc again until the water evaporates.
I was able to fix this fender with a disc and dolly |
#15 | |
Brian
#16 |
There you go, you can do it!
Brian
#17 |
Nice assortment, I don't even have a bumping hammer as large as the red one. You might want to see if you can find or fabricate a lone slender dolly, there are a few places on these where you need to be able to get some mass up and between to panels.
