02-01-2014, 02:55 PM | #1 |
Gauge's, Cluster's, and Dash'es
Let's see those Gauge's, Bezel's, Dash's, Etc...I've searched the forum and haven't had good luck. I've seen some pics of some custom made bezels on here, but they are scattered all throughout the build threads. Some are bought,some are reconditioned, some are altered, some are full custom. Like tachometers in our trucks I've seen where and how to get and install the "OEM" style, and some where a aftermarket tach's has been installed in a factory bezel. I've seen some custom made stuff too, like the Dakota Digital offers, and some that are "Hand-Made". These are my personal favorites as it shows ones own design and skills in making a "1 OFF" piece. Anyways, if you've got a pic of your gauge, bezel or dash, Please post it on here. I am Looking for inspiration myself, as $800 for a new one on Ebay, just isn't in my budget. there are other, cheaper options, i know, so if you know of them, please post that also.
72 C/10, LWB, 5.7, Auto, with A/C F.B.I = Full Blood Indian Appalachia/Eastern Cherokee,"Tsalagi" |
02-01-2014, 03:05 PM | #2 |
Re: Gauge's, Cluster's, and Dash'es
Here's mine. It's a repurposed glove box door. The gauges are all Equus gauges. They are relatively inexpensive but they have been very accurate.
My build thread. |
02-01-2014, 03:28 PM | #3 |
That is awesome, I love the white faced gauges. And the glove box door, its almost a perfect fit. Did u just have to trim for the steering collum to fit? :dohh :I can't believe I didn't think of the glove box door, And I just painted and pinstriped my dash too, Luckily it's still tore apart
02-01-2014, 04:26 PM | #4 |
I just used a cut off wheel and cut out the inner panel of the glove box door. Then I welded two studs to the bottom to mount the panel up tight.(In the pic I haven't tightened the nuts up yet. That's why it is pulled away from the dash. Then I trimmed the door to fit over the steering column and drilled the holes for the gauges and turn signal indicators. All in all it was a pretty easy job.
My build thread. |
02-01-2014, 06:41 PM | #5 |
The glove doors and dash bezels were made to go in either position depending on what side of the road it would end up upon. If you look at it the whole cowel and even the frame is made that way as well. What I am saying they[the General ] did not need a bunch of different parts for the repurposed trucks to be either left hand or right hand drive. The Jeeps are famous for this as well. Next time your in the shop take a hard look at your truck and if the int. is out for sure you can see the dash will fit in the glove box hole pretty easy. If you have your motor out take a look at the fire wall and then image in your mind taking the firewall and flipping it around. It will make sense. Jim
02-01-2014, 11:14 PM | #6 |
Old member
Here are my 2 dashes. First one is all GM gauges I put the cluster together myself from several trucks. The only aftermarket stuff in the first one is the bezal and plastic lens. Everything else is pure GM classic gauges.
Speed warning,tach, oil, water and amps is 67-72. The clock is out of a 80's model truck it's quarts to! Tach has 67-72 factory wiring. The speed warning is out of a 70's model caprice. It's for a seat buzzer. Looks the same though except for the buzzer. 2nd cluster is all www.speedhut.com gauges with GPS speedometer which is what is in the truck now. Wouldn't go back to the factory now.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-01-2014, 11:54 PM | #7 |
Here's mine
02-04-2014, 04:56 AM | #8 |
Hand Crafted C-10
Lets hear more details! That is a SWEET bezel!
. Forum Guidelines and Rules
Buying and Selling Code of Conduct Become a Board Supporter! Truck FAQ Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member... |
02-01-2014, 11:55 PM | #9 |
Started as flat 1/4 plate alum
02-02-2014, 12:17 AM | #10 |
My Gauges and Dash
1968 SWB. GMPP 350/350 Turbo Trans, Edelbrock Performer & Carb. Hedman Hedders, Hooker Aerochambers Mufflers. Tuff Stuff Alternators. Remember, no matter where you go, There you are. Gary |
02-02-2014, 12:28 AM | #11 |
Here is another option. Stock gauge bezel, ashtray and glove box cover have all been custom overlaid with carbon fiber. Trim painted Gloss Black, interior of cab is Matt Black. Will post a pic of finished dash once its all installed. Digital Dakota Gauges.
http://67-72chevytrucks.com/vboard/s...d.php?t=509467 2008 Dodge 3500 Blue Tech 2013 Challenger SRT8 392 1972 Landcruiser Rock Crawler LS1 1969 4X4 Resto Mod |
02-02-2014, 12:57 AM | #12 |
oh my sweet Jesus. that is sexy!!
02-02-2014, 01:47 AM | #13 |
Love the pics, Thank you everyone for sharing, Their all great ideas. Hope we can keep this thread going! 96blazer; is that the white face overlay kit? and i see the tach mounted on the steer collum, but what is the under mount gauge
02-02-2014, 11:50 PM | #14 | |
Just a gimmck thing, but it's a big "Bullet" style Chrome housing and it fit into my "If it were 1968, what Hot Rod stuff would the interior have" Theme. The gauge is a pretty cool conversation piece.
02-03-2014, 12:05 AM | #15 |
oldschoolblazer@yahoo.com
can't go wrong with forum member "putter"
http://67-72chevytrucks.com/vboard/s...d.php?t=457264 |
02-03-2014, 12:44 AM | #16 |
before and after, tear down and some paint and elbow grease polishing the lens. finished off with the headlight and wipers switch "covers" lol
02-03-2014, 01:06 AM | #17 |
02-02-2014, 10:43 PM | #18 |
im new to the website so bare with me lol i attached some pictures of my gauge cluster hope it works! i got rid of the factory fuel level gauge and mounted my 5 inch autometer tach in its spot and bought an autometer fuel level gauge to go right next to the oil pressure gauge , and mounted my fast air fuel ratio gauge in the factory tach spot, and then backlit it all with white leds.
02-02-2014, 10:45 PM | #19 |
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
02-03-2014, 06:52 PM | #20 |
Haven't done anything special to mine just yet. I just started tackling the interior this past weekend.
I did however replace the bulbs with LEDs. Made a huge difference.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
02-03-2014, 08:27 PM | #21 |
Glove box door, gauges from 98 chevy, and plexiglass
"There's a force in the universe that makes things happen; all you have to do is get in touch with it. Stop thinking, let things happen, and be the ball." -Ty Webb |
02-03-2014, 09:15 PM | #22 |
JohnT71 thats pretty slick! I haven't seen that done before. Very nice.
02-03-2014, 10:37 PM | #23 |
Here's a pic of my blazer dash.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
02-03-2014, 10:52 PM | #24 |
before and after led light swap |
02-03-2014, 11:03 PM | #25 |
3 pod Dash, I deleted the dash pad and speaker grill.
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
