Old 02-05-2014, 03:23 AM   #1
littlevictories
POLL: favorite method for removing busted exhaust manifold bolt
get out the vote!
A) try and weld a nut (it's under flush so this would be hard)
B) pull the head, use drill press and drill it out
C) free hand drill and use easy-out (this has cost me dearly before)
D) quit dickin around, pull the head, take to machine shop ($200 in labor and parts)
E) dump motor in CL seller's yard, maybe do some other landscaping too
littlevictories is offline   Reply With Quote
Old 02-05-2014, 04:03 AM   #2
ls1nova71
ls1nova71's Avatar
Re: POLL: favorite method for removing busted exhaust manifold bolt
The outer bolts seem to break off on engines when they get to around 100k, it's not an uncommon problem at all. I usually weld a nut on them. Even if it's a little below the surface, you can weld them since the weld won't stick to the aluminum. Just make sure they cool before trying to back them out after welding.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-05-2014, 04:05 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Which motor? stock heads on a truck motor, I'd just get a another set of heads and put them on, then take my old heads and have them ported (and that bolt taken out) while they are sitting on the bench, then throw the better set back on when its convenient.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-05-2014, 08:15 AM   #4
truckdude239
truckdude239's Avatar
Dorman now makes a clamp style thing that bolts to the back of the head and presses the manifold the block for the back bolts
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 02-05-2014, 10:52 PM   #5
68basket
more info please. Do you have the dorman number?
68basket is offline   Reply With Quote
Old 02-06-2014, 04:19 AM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
http://www.dormanproducts.com/p-6600...Repair%20Clamp
Old 02-06-2014, 10:35 AM   #7
Wasted Income
Boosted Member
Wasted Income's Avatar
Originally Posted by BR3W CITY View Post
Wow...what a half-assed way to "fix" a broken bolt.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 02-06-2014, 09:39 PM   #8
crazy longhorn
Fabricate till you "puke"
Yes that does look to be a half-vast way to fit a simple problem? longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-06-2014, 09:40 PM   #9
crazy longhorn
Yes that does look to be a half-vast way to fix a simple problem? longhorn
Old 02-05-2014, 04:20 PM   #10
littlevictories
I gave the weld method a shot and it worked.
Here's a link to the write-up I was pointed to on another board. http://ls1tech.com/forums/forced-ind...t-removal.html
Old 02-05-2014, 09:16 PM   #11
farmtrucks
farmtrucks's Avatar
Weld method - takes about 1 minute per bolt, use a wrench and get it out as quickly as possible.
farmtrucks is offline   Reply With Quote
Old 02-05-2014, 09:48 PM   #12
crazy longhorn
I did the drill & easy out, on 3 of mine....all were broken 1/8-3/16 below the surface? Flush to , a little stick out, I would have done the nut washer/weldem up trick Longhorn
Old 02-05-2014, 11:16 PM   #13
littlevictories
Gotcha, and that's what I've done for years (with varying luck) until today.
Mine was also 1/8" below flush, if you look at the bolts thats where the threads start on the neck. I just built up a little nub with weld, pushing as much heat into the busted bolt itself as possible. Then I sat the nut over that nub and went back at it. Let it cool down for a few minutes (It was 28*F today) and gave it a squirt with PBB, backed right on out.
Just make sure not to use any sort of coated nut...or corroded ones...lots of both in my random hardware can.
Old 02-06-2014, 06:14 AM   #14
chuckmc8
It's alsways something.....
chuckmc8's Avatar
I used the mig welder method- Mine was broken 1/4" below the head surface. Just place the nut over the broken bolt- set your welder pretty hot and tack the nut to the broken bolt. (The weld wont stick to the alum head) then put your 9/16" wrench on the donor welded nut and wiggle it back and forth gently and it will loosen up and spin right out. Like others have said, less than one minute procedure. The rear manifold bolt on driver's side seems to be the most common to pop off.
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 02-06-2014, 10:34 AM   #15
Wasted Income
Boosted Member
Welded nuts on them many, many times. Works like a charm.
Turbo diesel
Old 02-06-2014, 06:50 PM   #16
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Never tried it, I had to google it, so I posted the number lol.
I can't wait to start seeing engines in 'yards with these lol
Old 02-06-2014, 06:56 PM   #17
softballnrd27
Always a work in progress
softballnrd27's Avatar
buy new heads
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 02-06-2014, 08:52 PM   #18
truckdude239
http://www.youtube.com/watch?v=dzM1E9vf5G4#t=94
David fuller
2000 Tahoe 5.3l 378
Old 02-06-2014, 10:04 PM   #19
littlevictories
eh, looks like a good way to put it off for later
signed
-a fan of the red green show
Old 02-07-2014, 01:09 AM   #20
Andy4639
Old member
Andy4639's Avatar
Wink Re: POLL: favorite method for removing busted exhaust manifold bolt
I had one just today I had to weld another bolt to the head of the old bolt. It had rounded off. Welded a short bolt to it and it came right out.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
