02-07-2014, 04:49 PM | #1 |
My axle centerline
I installed my mustang ii front end. Axle is 1.75" forward of original. This is at ride height w 18" wheels. I think this is good. Thoughts?
02-07-2014, 04:53 PM | #2 |
Re: My axle centerline
Yep you done well looks good.
RIP John (Lambis), my beloved Father & best Friend. My Build 56 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=486721 |
02-07-2014, 05:00 PM | #3 |
Needs more low
Are the new gen Camaro wheels just for mock up?
65 C20 292 4spd 4:56 Eaton HO52 |
02-07-2014, 05:17 PM | #4 |
02-07-2014, 06:03 PM | #5 |
Is the truck for him?
02-07-2014, 06:04 PM | #6 |
02-09-2014, 12:04 AM | #7 | |
i have a mustII on my truk, it looked too high until i bolted everything in/on it. not sure mine would be streetable with drop spindles on it. doors, glass, interior, hood; everything you bolt on will drop the truck a little until it looks similar to this
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
02-09-2014, 03:07 PM | #8 |
02-09-2014, 03:51 PM | #9 |
56 - autocross
02-09-2014, 03:21 PM | #10 |
_Ogre knows what's up.
Jimi J from I-Oh-Way '57 Panel 3105 Met this deer... Roof Swap on my Panel Jim's Bread Truck |
02-10-2014, 02:10 AM | #11 |
Newbie! so can someone school me or direct me to a thread on why the front centerline needs to be moved forward when installing a mustang II style front end? much appreciated!
02-10-2014, 09:18 AM | #12 | |
To mustang II suspensions. I've seen camaro clips also moved forward. W larger wheels, the stock location does not look centered in wheel well esp when u lower the truck |
02-10-2014, 11:57 AM | #13 |
as someone has said, you need all the weight on it with the final tire/wheel choice and at final ride height to properly determine if the wheel will look centered, as the suspension compresses there is a slight rearward arc (more or less depending on type of suspension)
Learn to deal with reality, or reality will deal with you. |
02-10-2014, 12:04 PM | #14 |
Or of course if you know what the final height will be you can pull the suspension down with all thread in the shock location. I have done that before. So the truck could be brought outside to check it out. This is something so many people miss, roll it outside and take a look after a mod so you get a good look at it.
In this photo I have no engine in it. I used all thread to replace the shocks and pull it down where I wanted it. The rear is too high because I didn't do that but only removed the wheels and had the frame on shortened jack stands at the height I was going to have. Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
02-10-2014, 04:08 PM | #15 |
If you don't have it fastened in yet I think I'd slip it back 1/2 towards the rear and take some more photos.
I agree with Ogre on waiting buying or installing dropped spindles. It may be money you don't have to spend and it only takes a couple of hours max to swap both spindles if you do decide to go to dropped spindles. Brian showed what getting it right is all about in his photo of his truck. Those wheels are perfectly centered front and rear and really add to the looks of the truck in the process.
02-10-2014, 04:16 PM | #16 | |
02-10-2014, 06:08 PM | #17 |
Alright X2! I didn't want to be the one that said it.
02-10-2014, 07:30 PM | #18 |
Me too.
