Old 02-10-2014, 09:15 PM   #1
Andy4639
Old member
Andy4639's Avatar
Talking Hawks Headers
Here are the 1 3/4" long tube headers www.hawksthridgencamaro.com installed on my LSx 6.0 in the 71. They fit well with very little frame work. In fact I bet most can't even tell where they did the work on the frame.
http://www.hawksthirdgenparts.com/pr...Collector.html
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-10-2014, 09:45 PM   #2
Revorollerr
Re: Hawks Headers
$700 is budget? Holy crap. My schoenfield swap headers were like $300 and required no frame trimming. Not to knock em but budget is mis used I think haha
Revorollerr is offline   Reply With Quote
Old 02-10-2014, 09:50 PM   #3
Andy4639
Old member
Andy4639's Avatar
Wink Re: Hawks Headers
I will agree that the word budget is a little mis leading here!They are very nice headers though.
Old 02-10-2014, 11:31 PM   #4
Classic-Steele
Classic-Steele's Avatar
Re: Hawks Headers
Are you running Schoenfeld headers on a 67-72? I scored on a used set, and am hoping they'll clear the UCAs with the engine slid all the way back
Classic-Steele is offline   Reply With Quote
Old 02-11-2014, 12:54 AM   #5
Revorollerr
Re: Hawks Headers
Yes sir, my only issue was the factory linkage in the way and the factory trans crossmember, I trimmed 2" off the pass collector and chopped a U bend in half and spun one side 180* to make an S bend kinda. If it was my truck I would of built a new crossmember but at the time it was my brothers and he was on a budget.
Old 02-11-2014, 12:58 AM   #6
Classic-Steele
Re: Hawks Headers
Like your talking the shift linkage? How was clearance on the you're control arm? I've got a4l80 going in at the same time, and I'll be fabbing up a tranny, so that shouldn't be a problem.
Old 02-11-2014, 11:25 AM   #7
Revorollerr
Re: Hawks Headers
Ya shift linkage, I was using a th350 so it might be a tighter fit for you a little bit. I had tons of a arm clearance but I built my own solid mounts.
Old 02-10-2014, 09:46 PM   #8
jamesjones
Freakin Awesome!
jamesjones's Avatar
Re: Hawks Headers
Shoot, those might actually work on my setup.
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee
jamesjones is offline   Reply With Quote
Old 02-11-2014, 03:18 PM   #9
Custom 68
Custom 68's Avatar
Re: Hawks Headers
I did see lokar had a cable shift to take the place of the arm. I was going to look into it as I had trouble shifting all the way to "first"
I swapped to a manual so I never looked further into it.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
