Old 02-11-2014, 06:07 PM   #1
6768chevylover
6768chevylover's Avatar
Wilwood brakes?
Has any one used theses wilwood d52 calipers on their 15 inch ralley wheels and they dont fit cause they stick out to far and hit the wheel http://www.summitracing.com/parts/wi...6-bk/overview/ ?
6768chevylover is offline   Reply With Quote
Old 02-11-2014, 06:08 PM   #2
6768chevylover
Re: Wilwood brakes?
sorry. on a 67 chevy truck with 71 front end disc brakes?
Old 02-11-2014, 08:11 PM   #3
Pro Performance
Pro Performance's Avatar
Re: Wilwood brakes?
They are a direct replacement for the factory calipers, and should have no issues with your current wheels, if running them already. They do also sell these calipers in a kit with pads.
http://www.azproperformance.com/Wilw...140-11290.html
Pro Performance is offline   Reply With Quote
Old 02-12-2014, 02:17 PM   #4
6768chevylover
Re: Wilwood brakes?
they hit right on the bead where the face of the wheel and the ring itself are welded. I know they make wheel spacers but a wheel guy told me they really aren't safe to have on the front wheels.. Is this true?
Old 02-12-2014, 02:22 PM   #5
Pro Performance
Re: Wilwood brakes?
I have seen guys run large spacers, the ones that bolt to the hub and then the wheel bolts to it…. but, in my opinion, I would try to keep the spacer to a minimum. Shouldn't take much to clear, maybe .25"???
If you do run a small spacer, make sure the studs are long enough. I usually recommend getting the extended length lug nuts so that you get a little more thread engagement that get reduced when you run a spacer.
Old 02-12-2014, 02:40 PM   #6
Custom 68
Custom 68's Avatar
Re: Wilwood brakes?
I was running an aftermarket 15 inch wheel on my 68 that had been converted to disks. When I swapped to the D52 they did rub slightly I had to go to 18 inch wheels.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 02-14-2014, 07:41 PM   #7
68racer
Yeah baby!
68racer's Avatar
Re: Wilwood brakes?
I had to move the wheel weights on my 15" TTD's.
11.37 @116
68racer is offline   Reply With Quote
