02-12-2014, 05:48 PM | #1 |
polishing valve covers
Looking for some help as to the best and least expensive way for me to polish my aluminum valve covers and if that goes good maybe the intake too. Any help would be appreciated
02-12-2014, 06:14 PM | #2 |
Re: polishing valve covers
Howard,
This is the parts board. Items for sale. Your question should go in the general forum.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor. |
02-12-2014, 09:52 PM | #3 |
well !!!
72,2wd short bed cheyenne,350,350trans,air,tilt,tach,posi 373 gears 70 nova 5.3,350 trans 80 z28 350,350,trans,bought new 03 cat. 06 gmc swb ext cab |
02-12-2014, 09:56 PM | #4 |
mothers mag polish,lots of work but will do the job,intake i dont no
02-13-2014, 12:04 PM | #5 |
NOVAFROG; Thanks for the comeback. I didn't know about the detail forum until this post. After all the different kinds of posts on the parts forum, as Hillary would say, what difference does it make. Besides, how many members check the detail forum often?
I'll try the mag polish. Thanks again Howard |
02-15-2014, 12:30 AM | #6 |
Parts and more parts
Take some time and search the web for razor buffs. These are small round buffing wheels (3" to 4" in size) that can be used on either an air die grinder or an electric one. With the different polishing material and these buffs, you can polish your valve covers out without working your elbow grease out of the socket. I get my polishing sticks at local truck stops and then use the buffs to do the work.
Oh and by the way Howard, this is the detailing section. Just an observation
Frank |
02-15-2014, 02:12 AM | #7 |
Moderator
Are your covers and intake "polished" (smooth finish) already, or are they raw (as cast) aluminum?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
02-16-2014, 01:00 PM | #8 |
Thanks Frank and Leddzepp
The Valve covers are already smooth but the intake is not. I'll bead blast the intake and, with your information, polish the valve covers. Thanks for the help guys Howard |
02-20-2014, 06:20 PM | #9 |
You might consider clearing the intake once it's blasted, that way you won't have to polish it.
71 K20 64 GMC mud truck |
02-20-2014, 06:30 PM | #10 |
Careful on your choice of clear coat. I have seen many that turn yellow with the application of some engine heat.
Frank |
02-20-2014, 08:01 PM | #11 |
I'm in the process of doing mine right now... Jon (1963c-10) put 40hrs polishing one of his and it came out quite well
I started sanding with 180 and am at 400 now (granted mine had blemishes) going to work my way up to 1000 and finish with 1200 grit then polish Heres how he did his http://67-72chevytrucks.com/vboard/s...519869&page=16 and how it came out http://67-72chevytrucks.com/vboard/s...519869&page=17
Austin 1996 Chevrolet K1500 Silverado 1979 Chevrolet K10 Scottsdale - Carolina K10 - My 4.8L Twin turbo build - Project Short Stroke - Instagram - TheBlueBomber1996 |
02-20-2014, 08:06 PM | #12 |
Those pictures dont do any justice. I have seen the cover he did in person and its spectacular.
I've taken a break on mine since I'm going LS and can't use those covers on the new motor.
