Old 02-12-2014, 06:30 PM   #1
bigguy
86 GMC, Porterbuilt Mild front and rear
Figured I would finally post what I have been working on. The story goes that I bought my 86 GMC while on leave in 2009. It sat in my fathers garage for the next year until I could come back and get it. When I did get back, I did a mild build on it which included a Mcgaughy's 4/6 drop with big brakes, 20/22" Coy C5's, and a 5.3L/4L60E swap. I drove daily for a few months before getting deployed again and then it sat once at my fathers house. Fast forward to late 2012 and a separation from the Corps and it's build time! Name:  001.jpg
So for the second go around, I decided to run a Porterbuilt Mild dropmember front and rear. I built a cammed 6.0 LQ9, Performabuilt Stage 2 trans, 3.73 gears with eaton tru trac. I figured I would post some of the issues I have run into as well, mainly steering linkage and headers.
Attachment 1213713
Attachment 1213714
bigguy is offline   Reply With Quote
Old 02-12-2014, 06:36 PM   #2
bigguy
Re: 86 GMC, Porterbuilt Mild front and rear
A few build pictures
Old 02-12-2014, 06:39 PM   #3
bigguy
More build, 6.0L, raised bed floor with liner.
Old 02-12-2014, 06:44 PM   #4
bigguy
Fabbed ECM mount. Headers are Hedman Muscle rod. I had to notch the dropmember to get the correct angles for the steering. The drivers side header has the front tube rerouted to clear the joints.
Old 04-12-2020, 01:04 PM   #5
G-NUT
G-NUT's Avatar
Attachment 1213729
Attachment 1213730
Attachment 1213731
How did you connect your first u-joint at the steering column? Did you cut a piece of steering shaft stock and mount it in the residing location, and then mount the u-joint to that?
'84 Suburban C10 Silverado - laying pinchweld to the ground on 22/24.
/Porterbuilt / Accuair / Bonspeed / Landsail / Auburn Gear / Richmond Gear / Moser / Raybestos / ProMaxx / Edlebrock / Street Demon / Taylor Wire / K&N / MSD / KillMat /
SOLD: 1985 GMC Sierra Classic 2500 3+3 Crew Cab Long Bed
G-NUT is offline   Reply With Quote
Old 04-12-2020, 01:36 PM   #6
bigguy
No. The factory column has a DD shaft end already. These columns usually have the DD end or a splined end.
Old 02-12-2014, 06:54 PM   #7
79azc10
Looks sick , will nice to see more of it
79azc10 is offline   Reply With Quote
Old 02-12-2014, 09:47 PM   #8
snm95ls
Love it!
snm95ls is offline   Reply With Quote
Old 02-12-2014, 10:40 PM   #9
mooseknuckles
mooseknuckles's Avatar
sweet build bro!
mooseknuckles is offline   Reply With Quote
Old 02-13-2014, 02:03 PM   #10
bigguy
Thanks guys! Really appreciate your comments
Old 02-13-2014, 03:22 PM   #11
Houston Ben
Houston Ben's Avatar
Nice, I have the same year Chevy. I'm looking to drop in an Eaton True Trac as well, let me know how easy it is to install and how you like it!
Semper Fi!!
Houston Ben is offline   Reply With Quote
Old 02-13-2014, 03:49 PM   #12
bigguy
I haven't had a chance to use it yet. The installation was pretty straight forward. I used a nitro gear rebuild kit and it's the stock 10 bolt. You will need a press for the bearings and an in/lb torque wrench.
Old 02-13-2014, 07:09 PM   #13
stepside83
stepside83's Avatar
awesome build man im looking in to porterbuilt stuff now my self
stepside83 is offline   Reply With Quote
Old 02-15-2014, 11:34 AM   #14
bigguy
Thanks! Honestly, if I were to do it again, I would just go with the extreme version. It would be less fab and fitment issues.
Old 02-15-2014, 12:36 PM   #15
naphtali5725
naphtali5725's Avatar
nice!
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 03-13-2014, 05:07 PM   #16
bigguy
Header modified to clear steering.
Old 03-13-2014, 05:53 PM   #17
79azc10
Headers looks good
Old 03-13-2014, 11:57 PM   #18
Hankster
Hankster's Avatar
Looks good! I'd like to hear that beast.
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 03-14-2014, 12:04 AM   #19
mud.man.rj
mud.man.rj's Avatar
Like the look of the setup, headers fit nice, should be a real nice ride.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 03-14-2014, 12:21 AM   #20
Crew Laid
Great looking build so far.Good job modifying the headers to bit.
Crew Laid is offline   Reply With Quote
Old 03-14-2014, 09:55 AM   #21
bigguy
As soon as I can get the exhaust hooked back up, I'll get a video of it running.
Old 03-27-2014, 06:39 PM   #22
rwade
rwade's Avatar
I sent you a PM, and was wondering if you could get a picture and maybe some info on how you modified the inner frame support for the steering shaft clearance? I'm at that point and it would be a great help.
Thanks, Wade
rwade is offline   Reply With Quote
Old 03-31-2014, 05:25 PM   #23
bigguy
I'm at a crossroads right now and need opinions. Should I shave and repaint the firewall? Or, make a panel to resemble the a/c heater and put some undercoating back to look kinds stock?
Old 03-31-2014, 06:37 PM   #24
rwade
rwade's Avatar
Depends on the look your going for. I've redone so many things I've lost count. Thinking I'd be happy with it and not dough what I really wanted to do in the first place. If you like the look of a smooth newly painted firewall, do it now, or you'll be redoin it later. It's gonna be super nice either way!
Wade
Old 05-15-2014, 02:43 AM   #25
tinydb84
tinydb84's Avatar
Do you have any pics of you raising the bed floor? Or closer up pics of the mounts??
Truck looks amazing.
David
Instagram: myfabguy
headers, steering
