Running R12 in a Sanden?
Hey guys...gonna be installing my ls3 soon so it will obviously have LS accessory drive with a Sanden style compressor. My 72 C10 currently has factory air that works great running R12 with the stock A6 compressor.
My question is, assuming I buy a Sanden unit already filled with R12 compatible oil and R12 charge ports, can I just get custom lines made and plumb the new compressor into my existing components, and continue running it as an R12 system? I figured this would be the cheapest/easiest integration into the AC system already there. Didn't want to go 134 because I'd like to keep the stock condenser, and I'm told 134 doesn't work too well unless you upgrade to a parallel flow unit. |
![]() Join Date: Sep 2005
Re: Running R12 in a Sanden?
Only problem i see is finding someone that can pull the r12 out and save it till you done r12 here is going for 96 dollars a pound makes 134a swap over look really nice.
![]() Join Date: Dec 2012
I did ac work for 30 years There is a product called freeze 12 Its a r12 substitute I used it for years instead of R12 performs the same If your sanden is for 134 change oil in compressor to old style oil
1946 car hauler 1948 surburban 1937 chevy sedan 1940 olds sedan (project) 1967 ss396 chevelle 1999 dually crewcab(24000 miles) |
I have some lb's !!!!!!!!
meowMEOWmeowMEOW
I sold a container of R12 for $475 when they banned it the first time here.
Two years later they said it was okay to sell hotshots, then banned them... then came out with the replacements, and said it was ok again....go figure.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Looks like you can still buy R12 on eBay but it ain't cheap! Regardless you have to sign an affidavit saying you are a reseller, authorized installer, or will have an authorized installer charge/evacuate the system you are working on before they'll sell it to ya. Suuuuure!
Old member
The systemm will work but for the cost effictiveness I think your better off going 134-A now and be done with it. I can't tell any differance in performance of it compared to R12. Mine will blow 38-40 degree's sitting still.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
YUP, he's right on both accounts, even here in the desert !!
But to be sure, that is with the upgraded parallel flow condenser, right?
#10 | |
Old member
![]() Quote:
I still have the stock 1978 condenser and same evap. and R134 colder than the R12, I changed it 4 years ago, like it better
Interesting! I may give the 134 a shot.
damn, lived in the PNW all my life
never even owned an A/C car its all a buncha greek to me |
#15 |
you're welcome to join us. just make sure your wipers are sorted and your windows dont leak
typically 180 days/year with precipitation this side of the cascades |
#16 |
