02-16-2014, 12:19 PM | #1 |
need advice with lift...
Im new to the site, but have been reading a bunch of posts already which has helped tremendously.
I have a 1987 Chevy 1/2 ton and I installed a 4 inch Rough Country lift with 35 inch Mickey Thompsons. The truck sits higher up front and I dont like it. I was thinking of putting a 5 or 5.5 inch block out back or an add-a-leaf, but now im leaning toward removing 1-2 leaf springs in the front to drop .5-1.5 inches in the front. Any advice would be great... Should I remove 1 or 2? Which leafs should I remove? How much difference in height should I expect with each leaf? BTW, the Rough Country springs are super stiff, thats why I think it would be ok to do this. The front spring pack has 5 springs total. Thanks!! |
02-16-2014, 12:28 PM | #2 |
Re: need advice with lift...
You might be able to remove a couple leaves from the front pack,that might help some.What did you do to raise the rear? If you used the original rear springs with blocks of shackle flip,your springs might be sagged some & the reason for the nose sitting higher.The add a leaf is another option too.When I lifted my 82 K25 last year,it did the same thing,there are 5 leaves in the front as well.I added a couple more leaves in the rear as well as add a leaf.This set the rear a bit higher.I set this truck up for work,so stiff ride & extra weight capacity was what I wanted anyway.
1977 Chev C30 454/465/14ff DRW 1974 Chev C20.350/465/14ff " Rock n Roll ain't noise pollution" |
02-16-2014, 12:36 PM | #3 |
I also want to lower the front due to the amount of wheelwell space between the tire and the fender. There is a LOT of space. I believe the 4 inch lift from rough country is taller than 4 inches. I think removing front spring(s) will make it look better and ride better.
02-17-2014, 10:30 PM | #4 | |
02-17-2014, 10:42 PM | #5 |
Pics would be nice to help us understand what your dealing with. How much have you driven on the lift? It wont settle much but it will settle some. I would go out and drive it through some mild ditches or over some type of terrain prior to making changes if your only dealing with an inch or so.
Your spring pack is designed with each spring counting on the one below it being there to carry its respective part of the load. pulling two out of the middle would make me nervous, could cause the next leaf up to fail from lack of support. The previous post about your rear springs being original and possibly sagging from age is worth looking into as well. My truck is a fresh build and the front is a bit higher as well, does not bother me but I expect it to settle after its been driven some. Good Luck.
http://67-72chevytrucks.com/vboard/s...d.php?t=509467 2008 Dodge 3500 Blue Tech 2013 Challenger SRT8 392 1972 Landcruiser Rock Crawler LS1 1969 4X4 Resto Mod |
02-18-2014, 04:00 AM | #6 |
how wide a rim you got those Mickey T's on? if their wider than 8", i would think twice before pulling out some leafs.
do you REALLY want to lower your truck?! bring the back up to match. wouldn't go over 3" with a block. put add a leafs on my stepper-pia to put on, ride went out the window, & after 7-8 yrs, their wearing grooves in my leafs. you could replace your old rear springs with some new ones & small blocks for about $300. or for about $270 you could throw a set of airbags in the back to level it up (far easier than ripping your springs apart) |
02-18-2014, 08:23 PM | #7 |
I'm surprises the 35's don't rub already with a 4" lift unless you did some fender cutting like I did.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
02-19-2014, 09:50 PM | #8 |
i ended up taking the second to smallest leaf out of the front leaf bundle. my truck sits perfectly level now. also, the ride is MUCH better now.
i dont have any pictures right now, but it seems like the 4 inch Rough Country lift is closer to a 6 inch lift. My truck sat up higher in the front. I just didnt like that "bulldog" look. |
