Old 02-16-2014, 03:08 PM   #1
4th Gen C-10
Junior Member
What are these?
Found these items in a box in the back of the truck under a blanket.
The bottom right item has the following numbers stamped around the shaft:
3884936 1 69 14:43 GM
The top right item has the following numbers stamped into the top of it:
168 3880042-12-37-GM
The top left item is ~ 8" in diameter and the bottom left is ~9" in diameter.
Any help would be appreciated.
Jaybo
4th Gen. C-10 Build Thread
4th Gen C-10 is offline   Reply With Quote
Old 02-16-2014, 03:22 PM   #2
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: What are these?
They are ring and pinion gears for rear ends. The one stamped 14-43 is 3.07 gear ratio but I'm not sure what is it for.
The one stamped 3880042 and 12-37 is 3.08 gear ratio for a 8.2" Chevy car rearend. Like a Camaro or Chevelle.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 02-16-2014, 03:24 PM   #3
67_C-30
67_C-30's Avatar
Re: What are these?
After a little searching, it seems the 3884936 gear is for a 71 - 72 12 bolt truck rearend, like your truck has.
http://www.gmpartswiki.com/getpage?pageid=22424
My trucks
Old 02-16-2014, 03:23 PM   #4
jeh
jeh's Avatar
Re: What are these?
Ring gear and pinion gear. If someone else knows the number breakdown that should tell what there out of and the ratio.
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
