Old 02-17-2014, 12:15 AM   #1
draggin49
engine bogging under acceleration..
Ok, can someone give me a checklist of what items to look into.
I'm running a gm crate 350 ,all new accessories under the hood.
Truck ran great then all of a sudden the other day it is bogging really bad under accelleration,
Then it ran ok for a drive, now its back to bogging out really bad.
Thanks guys. It ran great for a week or 2 and this just started happening.
draggin49 is offline   Reply With Quote
Old 02-17-2014, 12:22 AM   #2
WIDESIDE72
WIDESIDE72's Avatar
Re: engine bogging under acceleration..
Is it bogging down all of the time now? That may actually be a good thong as it is easier to diagnose a constant problem bs an intermittent one. Are your fuel filters clean? Is the distributor all new as well? Points or electronics? Have you checked the timing with a light?
WIDESIDE72 is offline   Reply With Quote
Old 02-17-2014, 01:09 AM   #3
draggin49
All new distributor, plugs,new edelbrock carb, fuel filter looked clean, brand new gas tank so it didn't have any nasty stuff it could be sucking from there.
Turned the key, can hear the electronic fuel pump goin.
Old 02-17-2014, 01:10 AM   #4
draggin49
My mechanic timed it before I took it from the shop, I gotta have a friend bring a timing light by my house to check it
Old 02-17-2014, 01:42 AM   #5
draggin49
Oh i forgot to answer , no points newer style hei I believe
Old 02-23-2014, 03:49 PM   #6
dibbleg
my or may not help, but mine was bogging real bad under acceleration and it turned out to be a bad accelerator pump in the carb
Chris Mead Tattoos
dibbleg is offline   Reply With Quote
Old 02-23-2014, 04:30 PM   #7
bigmac73
bigmac73's Avatar
i would make sure the choke is fully open
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 02-23-2014, 04:37 PM   #8
lha1992
lha1992's Avatar
Deff check fuel filter, make sure the choke is open. Quite possibly the accelerator pump is bad.
lha1992 is offline   Reply With Quote
Old 02-23-2014, 04:40 PM   #9
draggin49
Update, took it back to my mechanic, it was a defective carb I will have to ask which part was defective specifically. summit said ship it back so a new one is in route so that's a plus.
