Old 02-19-2014, 12:13 AM   #1
Rude Ron
Rude Ron's Avatar
I need to get my gas tank out of the cab question?
Hello, can I get some advice from you guys on what's the best way to go with a under the bed gas tank? I have a chop top short bed C10 fleetside and need to get the tank out of my cab for leg room purposed, is a after market aluminum style tank or a suburban or blazer style tank best? I want to put it behind the rear end thx for any advice
Edited By Staff
"If I had all the money I've spent on Trucks, I'd spend it all on Trucks"
Rude Ron is offline   Reply With Quote
Old 02-19-2014, 12:43 AM   #2
colgad
colgad's Avatar
Re: I need to get my gas tank out of the cab question?
I did the 69 Camaro tank for my 67. Here is the link that I used.
http://67-72chevytrucks.com/vboard/s...d.php?t=423035
I just didn't want to fill the tank through the truck bed floor.
I liked the through the licence plate door style better
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 02-19-2014, 01:03 AM   #3
Rude Ron
Rude Ron's Avatar
cool idea, the tank seems to sit pretty low though? I do like the rear fill idea for sure.... clean
Edited By Staff
Old 02-19-2014, 12:50 AM   #4
eric8
Let me know how heavy that stock gas tank feels when you pull it out. I'm doing an LS swap so won't be using the stock tank either, but I may just leave it bolted in place as long as it is not ridiculously heavy. Are you really going to get more legroom? The top portion of the back of my bench seat already hits the cab when I have it pushed all the way back.
eric8 is offline   Reply With Quote
Old 02-19-2014, 01:02 AM   #5
Rude Ron
Rude Ron's Avatar
I have a big chop on my top, so a guy here on the forum to me his friend had the same big chop and the same problem no leg room... once you drop the bottom seat to the floor for head room,,, so his friend removed the behind the seat tank, cut the seat back frame down a bit and walla, the seat goes back where the tank once was! he said his friend now has more leg room than his stock 69 has,,,, what a great idea he gave me, now I just need to move my tank to the back
Edited By Staff
Old 02-19-2014, 01:47 AM   #6
K10 STEPSIDE
K10 STEPSIDE's Avatar
I had one welded for mine. It is fairly simple 20" by 10"-12" by frame width. with angles welded to the sides to mount it to the frame rails, and baffles inside. Then welded the original filler neck on and cut a hole in the wood bed. I will cover the hole later. Use a pick up system of your choice (I used one from a 79 chevy pickup). My tank holds around 17 gallons I think you could hold 12-13 and be flush with the bottom of the frame. Also if you don't want to delete the gas cap. I welded a nut to the back of my gas cap and used a metal spacer on the inside squeezing the rubber grommet between the spacer and the gas cap to fill the hole. most people assume it is still the gas cap, and get confused when they see the one in the bed.
This is the best I have of the "fake" gas cap. Please ignore the weird looking fella
_______________________________________________
A project can be finished, but a car is never done.
1967 chevy K10 step
2002 chevy Impala
Latest Project http://67-72chevytrucks.com/vboard/s...d.php?t=605308
K10 STEPSIDE is offline   Reply With Quote
Old 02-19-2014, 01:58 PM   #7
Rude Ron
Rude Ron's Avatar
clean job all the way around, except for the dude in the seat...lol,,, joking
Edited By Staff
Old 02-19-2014, 12:54 PM   #8
cool68
have you done a long search here on moving tank? - lots of info has been posted.
cool68 is offline   Reply With Quote
Old 02-19-2014, 02:00 PM   #9
Rude Ron
Rude Ron's Avatar
no I'm not smart enough to think of that....LOL I think I'm just going to go with a custom welded style and a filler in the bed floor
Edited By Staff
