![]() Join Date: Sep 2005
temp fitting question
So i got my new guages today i bought the autometer 2277 m12x1.50 to 1/8 adapter i had to drill the center out but the temp prope doesnt reach out of the adapter will that matter?
Also thread sealer or no thread sealer on the temp sensor?
meowMEOWmeowMEOW
Re: temp fitting question
I'd imagine having the probe protrude into whatever it is you measure would be beneficial to getting an accurate reading.
Is this oil temp, trans temp or coolant temp? I suppose technically as long as the heated fluid can touch the probe it will give a reading, but having it tucked inside the adapter may lead to an air bubble, or unusual fluid flow in that spot, giving erratic signal. As an example, having a temp sender partially unscrewed gives erratic readings, I would think this could as well.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Its the coolant prope
I use teflon tape on coolant stuff. Not much pressure, but leaks p*** me off.
With coolant temperature, I wouldn't be too worried about lack of coolant flow - the coolant will conduct the heat well enough the reading should be pretty accurate.
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
I had to do the same with mine...works fine...
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
this is what im working with
yep.....you have to remember it's coolant, so it's gonna find it's way in there...at least that was my thoughts....
Fabricate till you "puke"
The auto meter sensor (made to screw into that adaptor), does not set as deep, as the one that you drilled? Still , it is about right on, with the stat? The stat is around 190 ish....(205 on/195 off , on the elect fans). The guage does not dance around
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Okay that's what I wanted. To hear. Did you use telffon or sealant on yours? I've been told it will effect the ground but factory Senors had sealer on them new
That copper washer should seal it....that said, I did use a little thread sealant, not tape.... Mopar, or ARP, but just lite on the threads, as said the copper washer should seal it? longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... Last edited by crazy longhorn; 02-27-2014 at 02:09 AM. Reason: spelling |
I didn't use sealer on mine, just the crush washer.
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's. 68 Charger R/T - #'s matching 440/auto car, 499/727/3.91. 68 GTX - 440/4-speed, Dana 60. 44,000 miles. 71 SWB C10 - LQ4+S476r 06 Duramax - LBZ - Exhaust, EFI Live, etc... |
