Old 02-25-2014, 05:07 PM   #1
donthekawguy
donthekawguy's Avatar
66 front shock numbers needed
I'm lowering the front with 2.5 inch spindles and 2 inch shocks. I need part numbers for 2 inch shorter front shocks. I also need to know if I need to use a shock relocator kit with only 2 inch springs. Thanx!
66 shorty
donthekawguy is offline   Reply With Quote
Old 02-26-2014, 06:59 AM   #2
panhandler62
Java Mechanic
panhandler62's Avatar
Re: 66 front shock numbers needed
Any suggestions for this setup?
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 02-26-2014, 09:28 AM   #3
donthekawguy
I meant 2 inch springs. I googled it but only found the super high end stuff for almost 60 bux a pop.
66 shorty
Old 02-27-2014, 01:04 PM   #4
aggie91
I'm just glad to be here!
aggie91's Avatar
Look at this spread sheet:
Since you only changed the springs to 2" drop coils, you did not change the compressed length of the shock unless you removed or cut the bump stop on the lower a-arm. If the final comppressed mounted length of the shock is 9.75" or more you can use KYB # 344068 Excel G or KYB# KG5409 Gas A Just shocks on the front.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-27-2014, 05:58 PM   #5
donthekawguy
I will probably cut the bump stop about 3/4 of an inch. Thanks for the numbers!
66 shorty
