02-27-2014, 06:12 PM | #1 |
20" wheels in a 47-54 chevy truck
I have a Mustang II with 2" drop spindles. I want to run 20" x 9" wheels with 255/45/20 tires wondering if anyone is running this setup and if so, what offset wheel are you using. I don't want my tires to rub on the front fenders and it's hard to guess on what's going fit and not rub with this big of a wheel.
Thanks |
02-27-2014, 10:52 PM | #2 |
Re: 20" wheels in a 47-54 chevy truck
Just so everyone knows the tire wheel combo is not that big. It's 28.5" tall a 15" with 275 series would be close to the same height. So if you have a 28.5" tall wheel and tire combo that is 10" wide what offset is your wheel to miss the fender?
Thanks |
02-28-2014, 12:09 AM | #3 |
Youngrodder is our resident go to guy when it comes to big rims and rubber band tires. His is one of the few trucks they look right on.
02-28-2014, 12:44 AM | #4 |
I have a m2 ifs without the 2 inch drop and just measured with a buddys wheel wright gizmo for a 15 inch rim 235 75r tire and got a 3 inch negative offset . Don't know if that helps or not should add that I used a 7 inch wide rim for the calculation
02-28-2014, 12:51 AM | #5 |
Use THIS:
http://www.customtacos.com/tech.old/...php?article=40 ...to figure it out yourself. The only true way to know.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
02-28-2014, 01:11 AM | #6 | |
I will pm youngrodder |
02-28-2014, 11:22 AM | #7 |
This doesn't answer your question either, but is a good resource to see what each tire/wheel spec will do to the overall setup you have. Nice way to compare 2 different sets as well..
http://www.rimsntires.com/specspro.jsp
'58 Apache |
02-28-2014, 11:53 AM | #8 |
It would be really hard to say for sure what will work with your vehicle since its not the same as everyone elses. On later trucks its easier because they use specific parts and everyone pretty much uses the same, but with yours being MII drop spindles narrow arms and who knows if the front end is mounted slightly different than everyone elses by even a MM or two. All that put together means that we can say that a +/-##MM wheel works on my truck, but may be to tight for yours. Really your best bet is to go out there with a couple rulers and a plumb bob to get the measurements specific to your truck.
03-02-2014, 07:10 PM | #9 |
This setup has 20's on the rear and 18's up front. I typically don't like the bigger rims on these rigs, but this looks great.
http://www.customclassictrucks.com/f..._pickup_truck/
1951 Chevy 3100/S-10: http://67-72chevytrucks.com/vboard/s...d.php?t=406072 1957 Chevy 3200 1971 2WD Blazer - Sold |
03-02-2014, 11:25 PM | #10 |
The Blue truck that Groyd posted the link for is one of those few that looks decent with the big wheels and the 18's on the front have a lot to do with that.
Personally I don't like the looks of the big wheels and ultrma low profile tires on the older trucks and the "Progressive truckers" have slapped me for voicing that opinion previously but that stems more from the fact that the local tire stores seem to only sell the ugly gaudy wheels that look like the guy who designs the battle axes for World of Warcraft designed them. Locally I believe it's called the Gangsta bling look.
03-02-2014, 11:35 PM | #11 | |
03-03-2014, 05:36 PM | #12 |
Dont know if this will help but mine are 20 X 8.5 on front with 6.250 BS and 245/45/20 tires.
03-03-2014, 09:44 PM | #13 | |
Thanks |
03-06-2014, 10:48 AM | #14 |
Thanks... Mine is sitting on an s-10 frame with 4-link and air ride. You can check out the build on my page. Im just not sure how to link the thread just yet.
01-30-2019, 03:55 PM | #15 |
01-30-2019, 03:56 PM | #16 |
03-08-2014, 02:16 PM | #17 | |
That might be a question for Youngrodder and the others with trucks on the street with low profile tires and big (over 17 inch) rims, how many miles a year do you put on your trucks and how many long road trips have you actually done or do you trailer the truck everywhere because it is a "show" truck? I don't ever remember seeing anyone's thread on road trips on 20's in their trucks where they drove 1500 or 2000 miles one way across the country and it is something that makes me wonder if they actually get driven distances.
03-08-2014, 02:59 PM | #18 | |
03-09-2014, 12:13 AM | #19 |
takes all the guesswork out
http://www.summitracing.com/parts/php-01201
1971 Corvette convertible 454@ 525 hp 1936 Chevy Truck street rod 1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up 1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html 1950 custom Chevy Truck |
03-03-2014, 09:35 PM | #20 |
nice rollin roosterlike the stance..what suspension are you running..not to thread jack
04-30-2014, 07:45 PM | #21 |
Does the rear fit without tubs?
1949 Five Window, 1973 Step Side, 2000 Z71 |
04-30-2014, 09:19 PM | #22 |
WOW!!!! Looks amazing!! I want that!!!
01-31-2019, 02:02 PM | #23 |
I found this link the other day. It's from Art Morrison. With a 57.75" WMS and a 9.5 rim, they recommend a 5.5 backspace. With an 8 " rim they recommend a 4 inch backspace.
With a 57 WMS, they recommend 5 for 9.5 rim and 3.5 for 8 inch rim. Of course they are using Wilwood Pro-Touring spindles and Wilwood brakes. If you move up to the 13&14" brakes, more backspace is required. http://artmorrison.com/instructions/...structions.pdf |
01-31-2019, 03:01 PM | #24 |
anybody have a pic showing the wheels turned to lock both ways? do they rub over a bump with wheels turned? looks like they would but pics can be deceiving.
01-31-2019, 11:20 PM | #25 | |
I am usually in the measure once, cut till it fits group, but when the wheel manufacturer says "if your wheels dont fit, they are still your wheels" I tend to spend a little extra time with a tape measure. I think I could have gone another 1/2 inch less backspace.
