Old 03-01-2014, 06:19 PM   #1
cbenney
Linkage getting stuck between gears
Hi everyone – I have a 3-on the tree and my linkage gets stuck between gears. I am thinking that I need to change out the bushings/hardware. As you can see in the picture it is really worn… Does anyone know where I can purchase this kind of hardware? I checked my LMC catalog and I did not see it in there. The three pictures are two on the column and a picture at the tran. If you have any other suggestion - always appreciate everyone advice.
Thanks for your help!
cbenney is offline   Reply With Quote
Old 03-01-2014, 06:38 PM   #2
71Sixer
71Sixer's Avatar
Re: Linkage getting stuck between gears
Check out this thread. I can't help you out with a rebuild kit, but this explains how to adjust the linkage to keep it from hanging up.
http://67-72chevytrucks.com/vboard/s...d.php?t=215307
71Sixer is offline   Reply With Quote
Old 03-01-2014, 06:51 PM   #3
cdowns
cdowns's Avatar
i buy parts at the local autoparts store
Old 03-01-2014, 06:54 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
New bushings and hardware should fix your problem. I've bought the parts from Classic Parts up in Missouri for several linkage rebuilds over the years.
http://www.classicparts.com/1960-76-.../#.UxJkjZK9KSM
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-02-2014, 07:42 PM   #5
cbenney
Just ordered these today - thanks for the info Kevin.
Chris
Old 03-01-2014, 06:55 PM   #6
cees
cees's Avatar
Check rockauto and see if you can pull the part numbers off and then shoppe around to see if any other parts stores or online shoppes (summit or Jegs) sells it
cees is offline   Reply With Quote
Old 03-01-2014, 07:18 PM   #7
cbenney
You guys rock!!
Thanks for your feedback!
Chris
Old 03-01-2014, 09:49 PM   #8
hugger6933
Before you buy ANYTHING adjust that thing or you money. The thread that was posted I didn't read of course but there is a simple guide in the FAQ or the truck tech section of the home page of this site. If you have not been there it is worth the time investment to do so. The project ideas and quick and simple fixes for thing such as the hanging linkages really pays off. I bought a 70 3oot truck and had trouble driving to my shop as the shifter would hang a bit shifting on the ride home and I adjusted as the post said and then it was like new. The bushing were worn but it shifted so much better. Jim
hugger6933 is offline   Reply With Quote
Old 03-02-2014, 07:08 PM   #9
1971 cheburban
How to fix it? Get a rock crusher, ha ha ha ha. Or a floor shift conversion for the 3 speed. Summit just had the truck 3 speed for 40 bucks, plus it looks cool
1971 cheburban is offline   Reply With Quote
Old 03-05-2014, 07:14 PM   #10
GRX
GRX's Avatar
New bushings and proper adjustment as in the link will help immensely.
That is what I did. Installed the Hurst floor conversion kit. Probably the best thing I did to this truck. Much easier shifting. No disputing that 3 ott coolness factor though.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 03-02-2014, 07:48 PM   #11
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
It may just be that you need to practice shifting it ? Anybody else can try to drive my 67 and they tell me the shifter is messed up , I can drive it 7 days a week without a problem ? Is mine tore up ?
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 03-02-2014, 07:55 PM   #12
19673ontree
CAN'T FIX NOTHIN
Here is how to shift a 3 on the tree !
#1 starting from 1st gear pull back on the shifter towards the steering wheel raise the shifter up to neutral while holding pressure on it towards the steering wheel this keeps the levers from trying to go in two gears at once which is what hangs them up
#2 let it fall gently towards the dash and push slightly towards the dash and raise it up into 2nd gear
#3 push gently towards the dash from 2nd gear and pull down to 3rd gear
it dont matter if the bushings are worn or not it will shift like this ,,,,,, good bushings do help
underdash AC
Old 03-05-2014, 02:55 PM   #13
Sixteen Tons
Sixteen Tons's Avatar
X2 on 71Sixer's link. That single quick & simple adjustment will make your 3OTT shift like (well damn close!) new.
Wanda - 1969 C/10 LWB 250 I6 3OTT
LWB>SWB
Sixteen Tons is offline   Reply With Quote
