Old 03-02-2014, 07:03 PM   #1
4x4K10
Will this work?
Found a 1987 350 vette engine on craigslist for a pretty good price. Im looking to put this into my 85 k10. I have the original 305/700r4 in it right now. What im wondering is can i drop the l98 in and mate it to my 700r4 and go or not? Also if i cant, what will i need in order to make this engine work in my truck? Ive searched the internet for this swap but all i have found is threads talking about how it would be better off going for an LSx swap, but i dont have the funds for an LS swap at the moment. Thanks for your help
4x4K10 is offline   Reply With Quote
Old 03-02-2014, 07:12 PM   #2
notallthere
Re: Will this work?
I may be wrong but since the 700R4 in the vette is not electronically controlled it should not be an issue for it to bolt up to your trucks transmission. Are you dumping in all of the fuel injection on the motor or switching it to carb?
notallthere is offline   Reply With Quote
Old 03-02-2014, 07:31 PM   #3
4x4K10
Re: Will this work?
If i were to get the engine i would most likely keep the fuel injection.
Old 03-02-2014, 07:30 PM   #4
79Betty
79Betty's Avatar
Re: Will this work?
It'll Bolt in but pretty sure 87's have 1 piece rear seal n center bolt valve covers. If your reusing your intake it will be a bolt in swap. PRETTY sure you will have to get a new flexplate for the seal difference. I'd check at a parts store to see if they are the same part number or not.
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 03-02-2014, 10:40 PM   #5
JustTom
Re: Will this work?
If you're paying a premium for the "vette" engine, verify that it is.
Casting numbers, etc.
It seems a lot of 350's on CL claim to be "vette" engines, a common sales tool.
Tom
JustTom is offline   Reply With Quote
Old 03-03-2014, 10:51 AM   #6
nekkidhillbilly
Re: Will this work?
unless you getting if for like under 400 bucks its not the best choice. those 87 crossfire 350s suck. last thing id do is keep that efi setup. my advice would be what you dont want to hear get a 4.8 ls and 4l60e sell all your extra stuff. you can find them usually under a grand.
nekkidhillbilly is offline   Reply With Quote
Old 03-03-2014, 05:00 PM   #7
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
Re: Will this work?
Originally Posted by nekkidhillbilly View Post
unless you getting if for like under 400 bucks its not the best choice. those 87 crossfire 350s suck...
87 Corvette 350 engines are not crossfire injection. They are TPI.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds
ElGracho is offline   Reply With Quote
Old 03-03-2014, 07:37 PM   #8
Jonboy
Slots go on anything!
Re: Will this work?
Some of that depends on who you ask. CFI isn't much different from the TBI found in our trucks, once you understand it. If you adapt it to run a 7747 ECM, it performs similarly to TBI. The main difference is that it has 2 throttle bodies with a single blade and injector each, where TBI has a single throttle body with 2 blades and 2 injectors. The reason they are so maligned is that the ECM was pretty primitive. When it works, it works pretty well.
Doing a TPI swap and an LS swap are really apples and oranges. Most of your accessories, mounts, and trans will work if you are doing the TPI swap. Not so much with the LS swap. While the LS swap will probably net you more power, one would have to look at their mechanical abilities and see if it is for them. I like the look of the TPI swap, but that is just me.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 03-03-2014, 05:36 PM   #9
nekkidhillbilly
Re: Will this work?
yeah i forgot it was tpi in 86 or so. still not anything real desirable though 230 hp. unless it was for a steal i wouldnt go out of my way to get it. if over 400 bucks i wouldnt go for it.
Old 03-03-2014, 06:42 PM   #10
school boy
school boy's Avatar
Re: Will this work?
if its a 87 tpi engine out of a corvette, it will have the l98 aluminum heads. The tpi Camaros had the l98 iron heads
school boy is offline   Reply With Quote
Old 03-03-2014, 07:24 PM   #11
nekkidhillbilly
Re: Will this work?
yeah still 230 hp not much over a stock 350
