Old 03-02-2014, 08:01 PM   #1
Larry64
Cab mounts
1964 short stepper. How does one go about jacking up the side of the cab to change the mounts?
Thanks Larry
Larry64 is offline   Reply With Quote
Old 03-02-2014, 08:31 PM   #2
PGSigns
PGSigns's Avatar
Re: Cab mounts
Is the truck complete or just the cab?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-02-2014, 08:55 PM   #3
Larry64
Re: Cab mounts
The truck is complete.
Larry
Old 03-02-2014, 09:42 PM   #4
dougf
dougf's Avatar
Re: Cab mounts
Hi, I just did this on one side. What I did was I took off the cab bolts on the right and rear of the side you are replacing (They are usually really corroded and need replacement). I then jacked up the cab just an inch to relieve the pressure and used a jack stand to support the cab. No need to jack up any further. Good luck!
dougf is offline   Reply With Quote
Old 03-03-2014, 02:46 PM   #5
Larry64
Re: Cab mounts
Thanks Doug.
Larry
Old 03-03-2014, 04:49 PM   #6
Old Bleu
Old Bleu's Avatar
Re: Cab mounts
I just replaced the cab mounts on my '64 a few weeks ago. I just loosed the front and rear mounts a bit on one side, then used a floor jack to raise the front enough to slip the old mount out and the new one in. Then started the nut, but left it loose. Then raised the rear enought to slip the mount in and out. Lowered the rear and then tightened up both front and rear on that side. Then repeated it for the other side. I was pleasantly surprised at how easy it was!
Old Bleu is offline   Reply With Quote
Old 03-03-2014, 09:00 PM   #7
Larry64
Re: Cab mounts
Good advice old Bleu.
Larry
