Old 03-03-2014, 05:51 PM   #1
DeadheadNM
Carpe manana
DeadheadNM's Avatar
So this is what a rolled K5 looks like
I guess a roll bar can be useful. The Hickey roll bar (not the one in the pic) seems a little puny but better than nothing I imagine...
Old 03-03-2014, 07:38 PM   #2
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: So this is what a rolled K5 looks like
How depressing, I guess anything that helps keep space between the head and asphalt is a good thing....
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 03-03-2014, 09:05 PM   #3
cleszkie
cleszkie's Avatar
I've seen one without a roll bar go tires up. The windshield folded completely flat on top of the driver and passenger without putting up any kind of resistance. Yes, they were hurt bad. So even a small 4-point roll bar as seen in the picture is a life saver if not a truck saver.
cleszkie is offline   Reply With Quote
Old 03-04-2014, 02:15 AM   #4
Moreyel
Moreyel's Avatar
That's sad to see Deadhead. Is that yours? Where u in it? Everyone OK?
Makes me wanna look into a roll bar.
Anyone have suggestions on where to find one?
Still coming to NM this month?
Morey
72 Blazer, 70 El Camino SS, Anniversary HD FatBoy, 2020 Ram 2500, 80 Vette, 65 Chevy 3/4 Ton 4 W/D Pickup and some more.
Wife: 06 GMC Duramax 3500 4WD Single Wheel
Next: Rust removal on my Blazer.
Thinking of putting a 50 Chevy cab on a 76 Chev 4 WD pickup.
Members Met: Aldtime, DeadheadNM
Moreyel is offline   Reply With Quote
Old 03-04-2014, 05:19 AM   #5
Chulisohombre
Chulisohombre's Avatar
Damn that sucks. The roll bar more than likely saved their live. Hope everyone is ok. You can buy a kit on eBay for 300-500. Hard to find the stock rollbars anywhere.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 03-04-2014, 09:00 AM   #6
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Morey
Hi Morey - Thanks, not mine just pics I scrounged on the web. Not sure this helps but back in September a guy listed two Blazers and some parts. He had a roll bar - not a vintage bar as the OD of the tubes was much larger. He was letting that go cheap. Not sure I'll make it down in March but I will let you know. I actually like the clean look of no roll bar but my Blazer has a 4" lift and the higher center of gravity makes me think adding one as a measure of safety is a sensible idea. Pete
Old 03-04-2014, 09:22 AM   #7
Chulisohombre
Glad it wasn't Yours. A simple roll bar helps even in a road rollover. The window frame is weak to say the least. Years of internal rust leaves most of them pretty thin to begin with. I will be putting one back in this summer. The one that was in wasn't built very well and I believe was just schedule 40 pipe. Wasa six point though but blocked the glove box door and the p o cut it to be able to get it Open. I have a new one but the old spid is damaged on the stock one. I need to get one of the repro ones off The guy on here that makes them. I think the one on eBay that look like the one smittybilt used to make would work out prett good. I've thought about hooking the upper tubes to the windshield frame but it might be too much for it to handle off road when the body flexes.
Old 03-04-2014, 05:51 AM   #8
Gumby
Gumby's Avatar
Amazing how many you see running around with nothing but blind faith that the window frame will protect them.
Chevy GMC Trucks Find Of The Day
https://www.facebook.com/ChevyGmcTrucksFindOfTheDay or http://ChevyGMCTrucks.com
Gumby is offline   Reply With Quote
Old 03-04-2014, 01:18 PM   #9
BKSS67
Any one have a picture or any info on what a rolled K5 looks like with the top on?
BKSS67 is offline   Reply With Quote
Old 03-04-2014, 07:25 PM   #10
cleszkie
cleszkie's Avatar
I've seen that too. Just picture the same picture posted in this thread with jagged, broken fiberglass (or SMC) and more broken glass laying everywhere. The hard tops might buy you another half second to duck. By no means will they provide any sort of protection during a roll-over.
Old 03-04-2014, 03:00 PM   #11
Moreyel
Moreyel's Avatar
Thanks Hombre. I'm gonna look into one.
By the way, what's the difference between the two tops everyone's talking about. Double versus single wall. Is the double an insulated version?
Old 03-04-2014, 08:13 PM   #12
DeadheadNM
Carpe manana
DeadheadNM's Avatar
You bet. There are two versions of the K5 top; an early version (continued through 72) that was what I like to think of as a "double hull" similar to that on a boat with inner/outer layers (double wall), and a later version (beginning 71? def in 72) that had a single layer (wall). Double wall tops attach with bolts along the undersurface of the bedside so if you have panels (like a CST) these need to be removed before the top can be unbolted. A single wall top has top has top bolts so panels don't need to be removed, has additional reinforcement/construction to prevent the "sag" seen on 2x wall tops, and has dome lights. Post pics of your top from the inside and we can see which you have. Pete
Old 03-04-2014, 08:15 PM   #13
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Here's a burning Jimmy:
Old 03-06-2014, 04:51 AM   #14
Gumby
Gumby's Avatar
stuck, blew it up n burned it to the ground trying to get out......?
Old 03-06-2014, 05:02 PM   #15
DANTES JIMMY
DANTES JIMMY's Avatar
It looks like there is a line coming out of the winch maybe electric fire ??
ugly business either way
DANTES JIMMY is offline   Reply With Quote
Old 03-06-2014, 05:05 PM   #16
mtully79
mtully79's Avatar
Blazerman if those photos aren't reason enough to put in a roll bar I don't know what is. Scary stuff...
mtully79 is offline   Reply With Quote
Old 03-06-2014, 09:28 PM   #17
DeadheadNM
Carpe manana
DeadheadNM's Avatar
The caption that accompanied the photo said he left it running while helping a buddy who was stuck and the exhaust ignited some weeds. Doh! I've done that but managed to put the fire out and save my car (while my buddy ran off fearing the car would blow up).
Old 03-04-2014, 08:16 PM   #18
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Not sure what happened to this Jimmy - maybe plowed headlong into a clown car
Old 03-06-2014, 03:17 AM   #19
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Are you sure you guys want to see this????
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 03-06-2014, 03:18 AM   #20
BLAZERMAN
BLAZERMAN's Avatar
Another
Old 03-06-2014, 03:19 AM   #21
BLAZERMAN
BLAZERMAN's Avatar
Ouch!!
Old 03-06-2014, 05:06 PM   #22
DANTES JIMMY
i have always said that there should be a questionaire before they let you buy certain things
Old 03-06-2014, 07:11 PM   #23
tristan
Dibs on the skid plate!
tristan is offline   Reply With Quote
Old 03-06-2014, 09:31 PM   #24
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Rob what's the story on the flipped Blazer? Are you one of the guys standing next to it?!
Old 03-07-2014, 05:02 PM   #25
BLAZERMAN
BLAZERMAN's Avatar
Nope it wasn't me Pete...just some pics I found somewhere on the Internet years ago. I wish I knew the story behind it....I'm betting the outcome wasn't good for anyone that was in it.
