Old 03-03-2014, 11:34 PM   #1
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
B pillar to floor pic
Guys I am needing help figuring out what the b pillar to cab floor joint looks like as mine is ate up. Thanks Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 03-03-2014, 11:37 PM   #2
vectorit
What?
vectorit's Avatar
Re: B pillar to floor pic
Which side?
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 03-04-2014, 01:11 AM   #3
Livrat
Member #1049
Livrat's Avatar
Here is picture of a "sorta" rusty pickup OEM one
Livrat is offline   Reply With Quote
Old 03-04-2014, 02:35 AM   #4
Livrat
Member #1049
Livrat's Avatar
Here are "sorta" rusty burb ones
Old 03-04-2014, 06:47 AM   #5
71blksuper4x4
SWB 4x4 Collector
Thanks livrat .....I also need to see the inside...how it meets the floor. A view from inside the cab looking down at the pillar. Trevor
TREVOR
Old 03-05-2014, 01:47 AM   #6
Livrat
Member #1049
Livrat's Avatar
I'll try to get out to my parts burb tomorrow and take a couple pictures of the inside for you
Old 03-05-2014, 06:20 PM   #7
71blksuper4x4
SWB 4x4 Collector
Much appreciated Livrat! Just can't figure out if it overlaps the floor on the inside, goes under the floor, or doesn't even weld to the floor. The bottom inch is gone. Trevor
TREVOR
Old 03-05-2014, 07:00 PM   #8
magicoolbus
magicoolbus's Avatar
Went out and snapped a few. I just finished putting in both front outer rockers, my inner rockers were just fine. I cleaned up the 'channel' where the B pillar and floor met and put in some evercoat 2k seam sealer. I did the same to the drivers side. It just seemed like a good place for future corrosion so I nipped it in the bud Andy. The black is POR 15.
In the third pic, you can see my addition of a door switch. I put one in the third door pillar and one on the right barn door in the back. Regular sized door courtesy switches used on front doors are too big, so I used ones from a vintage VW beetle.
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
magicoolbus is offline   Reply With Quote
Old 03-05-2014, 07:28 PM   #9
Livrat
Member #1049
Livrat's Avatar
here are a couple, the pillar actually sits on top and curves over the side and bolts to the floor support
Old 03-05-2014, 09:07 PM   #10
71blksuper4x4
SWB 4x4 Collector
Thanks again, I appreciate it. Trevor
TREVOR
