Old 03-04-2014, 06:50 PM   #1
edflores
HELP!!!!!! Can't open door!!! 1964 Chevy c20.
Just bought a truck, based on pictures. Get it towed home. Get the motor going. About the start working on the brakes, but couldn't get in.
It was blocked in so I kept going in through the passenger side.
Handles moves mechanisms.
Door panel off, wd40 the latch area.
Used brut force and nothing.
Any tips or tricks?
edflores is offline   Reply With Quote
Old 03-04-2014, 07:02 PM   #2
66customcamper
Re: HELP!!!!!! Can't open door!!! 1964 Chevy c20.
Might try a floor jack with a block of wood under the rear cab corner and gradually raise while you pull on the door handle...worked for me when I couldn't get out and had to crawl out the stinkin' window.
66 Custom Camper
327/ 4 spd.
Bone Stock, down to the split rims
66customcamper is offline   Reply With Quote
Old 03-04-2014, 07:23 PM   #3
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Go in "Dukes of Hazzard" style... thru the window
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 03-05-2014, 12:23 PM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Ran into a similar thing when I was adjusting the door striker. Got it locked up.
I used a pry bar between the rocker and rear lower door area and carefully lifted the door while pulling on the door hand (button pushed in of course). Got it to finally pop open and I was able to readjust the door striker. Basically the striker put enough pressure on the release wheel that it would not allow the release linkage to allow the "star wheel" roller to move.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-05-2014, 12:50 PM   #5
rideblue00
rideblue00's Avatar
how about taking the inner door panel off and using a device to actuate the lock mechanism?
rideblue00 is offline   Reply With Quote
Old 03-06-2014, 02:19 AM   #6
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
My Drivers Door is Like That Just picked This Truck Up Going to Try with Plastic Pry Bar
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 03-06-2014, 11:41 AM   #7
chevy_mike
chevy_mike's Avatar
I know when I had the problem, I did pull the door panel off and worked the mechanism but it would not release fully. I had to get the load off the star roller to get it to release and that could only be done with lifting the door slightly.
Old 03-06-2014, 12:58 PM   #8
rideblue00
rideblue00's Avatar
ok i see. ive never had an issue like this
