Old 03-04-2014, 10:49 PM   #1
Sailor?
"Vacilando" The '68 not worth building
Well, my name is Jesse and this is a truck that a buddy, Nate, and I have decided to build for this year's annual Hot Rod Power Tour. Every year I build something different to take on the tour. It usually ends up being something totally thrown together at the last minute and we work through the issues on the tour. This year my wife told me that it had to be different. She gets the last two weeks of May off every year and I ALWAYS end up work 24/7 those two weeks to finish a vehicle. This year I started, what seams to me, way early. Nate and I had a couple different ideas for possible projects but kept coming across the same truck on our local craigslist. It looked to have a great attitude from the pictures and seemed cheap enough. However, we noticed that it had been for sale for over a month. Im sure you all know, if there is a short bed C-10 on craigslist, it doesnt stay there for long. We decided to give them a call and see if they still had it. Sure enough, they did. We drove out to take a look at the truck on thanksgiving day. The owner ended up being a high school shop teacher and this was one of the students recent projects. They had pulled the truck out of a farmers field and worked through all of the mechanicals. The truck ran, drove, stopped, all the blinkers worked, horn, new radiator, battery, etc. You could tell that they had went through all of the general maintenance stuff and replaced whatever they needed to get the truck back on the road. The owner was a great guy, also a local hot rodder with cool stuff. After looking over the truck it was obvious that the exterior of the truck was in terrible condition. Floors were gone, rockers, cab corners, bed floor, well everything needed to be sectioned or replaced. The price was fine but the truck just needed way too much. We actually left with intentions to not buy the truck. BUT.... we just couldnt stop looking at the truck and thinking about just how good the patina looked on it. The truck had been given a second chance by some high school kids and it was just too much to think that we were going to pass up on it. We went back and made a deal on the truck. Loaded it up on the trailer and brought it back to the shop.
Within a couple hours we devised a budget and a pretty solid plan of attach.
1. All new drivtrain. The truck was originally a straight 6, 3 on the tree. We would do a cammed 5.3L with an M21 4 speed.
2. All new suspension and steering. We want to be able to actually throw the truck around and have some fun with it. Needs to be a hotrod, not a lowrider.
3. Maintain as much of the original patina as possible. Obviously a lot will need replaced just to make the truck solid and safe again.
4. Do burnouts.
Here are some pictures of the truck on the first day I brought it in the shop.
Not important but, this is me on the right. Very concerned at this point. "WTF"
We decided to go ahead and get the front end off the truck and start pulling the drivetrain. Btw this is Austin, good friend and a great employee of mine.
Meet Corey. Super cool dude that interns at my shop.
Always a fun dude.
Corey got the motor pulled and the chassis stripped down.
No need for a crazy step notch here. Just a notch to keep the alxe from interfering. We are running Hotchkis 370lb, 6" drop springs in the rear with a set of our 1" lowering blocks. More on that in bit.
Also, a couple of the cab and bed mounts need to be fixed. The bushings had rusted out the metal.
Again keeping with a budget we just flipped the stock trailing arm brackets.
After the frame was wire wheeled and cleaned we moved it in the booth and sprayed it with some single stage gloss black. Nothing fancy, just making it clean again.
Sorry, I didnt get a picture of the frame alone painted black.
As for the trailing arms, the factory arms were totally rusted and coming apart. We had some 2x3" box tubing in the shop that would work perfect! I measured out the factory arms and made a set to the factory specs.
Here is a picture of the arms installed and the 1" blocks as well. I know, I know... yellow Monroes? Yep, we are on a budget and I totally dig the yellow. lol Reminds me of highschool.
This is fast forward a couple weeks. Now, the suspension and steering are finished and the motor/trans are mocked up. Here you can see we put together a watts link using some custom and off the shelf parts. The pivot and links are factory PT Cruiser.
Here is a picture of how it sits currently.
The 5.3 is in using stock mounts and brackets with a set of our adapter plates.
The M21 is looking good sitting on the stock crossmember.
We are also getting the opportunity to use a pre-production intake from Holley. They have made the dual 4 intake for LS engine but this is the first single 4 barrel intake for the LS from Holley.
Thats about it for now. This week we will be getting the motor back out to finish putting together and painting. Thanks for reading.
Sailor? is offline   Reply With Quote
Old 03-04-2014, 11:01 PM   #2
Saclandman
Saclandman's Avatar
Re: "Vacilando" The '68 not worth building
Very cool. I'll be watching this one to get a game plan for my '67.
Rich J.
1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD
2002 Chevy Tahoe 4X4 5.3L SOLD
2015 Chevy Silverado Crew 4X4 5.3L
Saclandman is offline   Reply With Quote
Old 03-04-2014, 11:49 PM   #3
nuke1
nuke1's Avatar
This will be one cool ride when done!! What cam do you plan on using for the engine?
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 03-05-2014, 12:35 AM   #4
Sailor?
Nuke1, thanks. We really think so. I put in a 224R cam with a 112LSA. LS2 timing set, comp pushrods, and PRC valvetrain. Going to turn 6800-7000 since we have a manual trans. I guess we will see how good the syncros are in the 4 speed!
Old 03-05-2014, 01:07 AM   #5
BossHogg69
motor exploder
BossHogg69's Avatar
Diggin' the fab work and the fact that you're using a stepside - I'm in on this one!
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 03-06-2014, 10:19 AM   #6
Low Elco
Liking this a lot! What shop is this?
Low Elco is offline   Reply With Quote
Old 03-06-2014, 10:41 AM   #7
Sailor?
Thank you. Level 7 Motorsports
Old 03-06-2014, 11:06 AM   #8
powerline84
Greasemonkey
powerline84's Avatar
this is a cool build..I want to do the power tour with my truck eventually.
1970 cst-10 longbed
speed
My Baby
http://67-72chevytrucks.com/vboard/s...=1#post3113923
powerline84 is offline   Reply With Quote
Old 03-06-2014, 11:43 AM   #9
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Nice!
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 03-07-2014, 09:51 AM   #10
Sailor?
Good morning Quick cell phone picture of the stock valve covers I shaved and did in wrinkle black. More pictures tonight of the engine all painted.
Old 03-07-2014, 01:43 PM   #11
mooseknuckles
mooseknuckles's Avatar
cool build!
mooseknuckles is offline   Reply With Quote
Old 03-07-2014, 01:50 PM   #12
Mater/10
Mater/10's Avatar
This Is AWESOME!
1964 Chevorlet Custom 10 350/350 ,ps,mb,A/c,BBW -Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=608625
1969 Chevy Nova 2 dr I6 250/powerglide
1967,68,69,70,71,72 Chevy Frankenstein
Mater/10 is offline   Reply With Quote
Old 03-07-2014, 09:04 PM   #13
Sailor?
I ended up not having a pilot bearing, so I couldnt get the trans on. However I did get some pictures of how the engine turned out. Im very happy with it so far.
Old 03-07-2014, 10:47 PM   #14
swamp rat
swamp rat's Avatar
Looking good!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-08-2014, 07:13 PM   #15
Sailor?
I got a new pilot bearing today so I was able to finish getting the transmission on. In case your wondering I am running an LS2 flywheel, 11" 10 spline clutch kit, and an LS2 pilot bearing.
Now I can start plumbing and wiring.
Here are a couple pictures I took this afternoon.
**** I am in need of a transmission yoke. If any of you have one, shoot me a PM. I believe it is a 27 spline, 1.5" barrel
Old 03-11-2014, 12:15 AM   #16
Missile Man
I'm Nate, part owner of this 67. We've been having a good time working on this project and I can't wait to see it all together. Great job on the thread so far Sailor?. Thanks to all for the comments. Carry on...
Missile Man is offline   Reply With Quote
Old 03-11-2014, 09:27 AM   #17
Sailor?
Any pics of the bed yet Nate?
Old 03-11-2014, 11:57 PM   #18
Missile Man
Um, well the bed is a little rough.
But, like the rest of the truck the exterior has fantastic patina and tells a great story. There's still plenty of good metal in this old bed and I'm confident that we can shore it up.
This corner was probably the biggest structural issue with the bed. It took me a good while to formulate a salvage plan. The repair is far from perfect but rock solid. No more saggy bed!
Old 03-12-2014, 12:34 AM   #19
70LonghornCST
Moderator
70LonghornCST's Avatar
Hello and welcome to the forum! This is a cool build thread. Subscribed to this one
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 03-20-2014, 03:03 PM   #20
SnatchRAT
SnatchRAT's Avatar
sick truck bros!!!!
SnatchRAT is offline   Reply With Quote
Old 03-20-2014, 03:53 PM   #21
steelhorse
steelhorse's Avatar
Cool project
steelhorse is offline   Reply With Quote
Old 03-20-2014, 05:30 PM   #22
aggie91
I'm just glad to be here!
aggie91's Avatar
Cool, I like when buddies get to gether to build something cool...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-23-2014, 07:18 PM   #23
Sailor?
Thank you everyone for all the compliments.
I have been working on wiring, plumbing, etc for the past few days. At this point I am just waiting on my Holley manifolds to finish the chassis.
The coils have been mounted behind the heads and wired. I also got the MSD box mounted and wired as well. You can also see that we ditched the truck accessory drive and made our own. The p/s pump bracket is stock but I cut the alternator mount off. I used an older alternator and some heims to tension. I did have to build an idler pulley mount. Seems like it will all work well but we will have to wait and see
Here you can see the battery mount. I still need to pull the battery and paint the box.
Fuel lines finished up.
Huge thanks to our friends at Holley.
Old 03-23-2014, 08:00 PM   #24
CanadianK10
Active Member
CanadianK10's Avatar
Awesome Fabrication work, looking forward to watching this one.
1967 K10 292, SM65 Transmission & NP205 Transfer Case
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=605048
CanadianK10 is offline   Reply With Quote
Old 03-23-2014, 10:22 PM   #25
tommys72
tommys72's Avatar
Ill be watching this one
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
