Old 03-08-2014, 08:40 PM   #1
grippin_c10
should i mount ford f-150 long travel suspension?
hey there im having quite the hard time trying to find/fab a long travel ibeam setup on my 81 c10 2wd.so should I just copy a ford f-150 ibeam kit and put that on? or do anyone of you guys got an idea or some input that would be vary helpful thanks.
grippin_c10 is offline   Reply With Quote
Old 03-09-2014, 12:23 AM   #2
Ziegelsteinfaust
Re: should i mount ford f-150 long travel suspension?
I have a 66 F100 that is in project status, and from the experience of I-beams to CV front end. I would say if you really want Long travel I beams get a Ford. Yes you can make them work, but the frame widths are extremely different.
I had a C20 cross member for a couple of weeks when I first got started on my F100 with the idea of making it fit. The Fords wide frame will practically slide over the Chevy frame, and you will effectively have a Z in the frame when connected. If my memory is correct you would have to shave the frame rails of the Ford about a 1/2 total to get it over the GM rails.
If you do this you will not want to run the early forged I beams due to them being rear steer, and you would have to mod you column to adapt along with wiring.
I would run the later beams post 87, and gain front steer which gives you the ease of hook up.
Or you could try to find a clip from a E150. They are front steer, but rather or not the have support for long travel suspension I do not know.
Either way I would use the 3/4 ton version, and get the camper special brakes. This way you have the factory big brake option.
Ziegelsteinfaust is offline   Reply With Quote
Old 03-09-2014, 10:47 AM   #3
grippin_c10
ford frame rails are only like 3in wider.and my truck is 2wd and I want to make my own ibeams or use a aftermarket ford kit. but can you explain a little bit more
Old 03-09-2014, 11:21 PM   #4
Ziegelsteinfaust
I was not aware of aftermarket kits to put I-beams on trucks.
Personally while I like F250's for pre-running I just don't think I would spend a bunch of money to do it to a Chevy.
Its your truck, and it can be a nice set-up.
Old 03-09-2014, 11:29 PM   #5
manimal
manimal's Avatar
You can also do a "Swing Set" steering set up. Check out Race Desert....LOTS of good info there. Ziegelsteinfaust gave you some good info as well. For lifted(bent) I-Beams, check out Auto-Fab. YES it's a LOT of work, but can be done....$$$$$$$
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 03-12-2014, 04:14 PM   #6
grippin_c10
yeah that's what I was going to do was a swing set steering and I cant register to race desert for some reason.
