Old 03-09-2014, 03:38 PM   #1
gen3usa
gen3usa's Avatar
Need some Mechanical help
First off thank you all for your help....scenario below...
Truck, 1985 Silverado 454 74k original miles
Driving home from work, when i let off the throttle to coast up the ramp, heard a back fire, then another and then engine died, I pulled over and pedaled the gas a few times and it ran rough, while manipulating the pedal to get her home, pulled up to house and it died again.
Yesterday went out and fired up like normal and drove around for about 20-30 min, then it started doing it again, as long as i keep my foot on the pedal some it stays started but if i take my foot off it runs rough and will die.
Any thoughts? Fuel pump was initial thought....help is needed as i want to have the beast representing daily on the road as the best truck made.
1985 Silverado C20
454 Gas Hog
74K miles no crust!
gen3usa is offline   Reply With Quote
Old 03-09-2014, 03:40 PM   #2
gen3usa
gen3usa's Avatar
Re: Need some Mechanical help
Oil pressure is great, battery is great, all things work flawless till now.
1985 Silverado C20
454 Gas Hog
74K miles no crust!
Old 03-09-2014, 03:47 PM   #3
Chevy3+3
I was gonna say TBI coolant temp sensor but see its an 85' so that doesnt apply
Chevy3+3 is offline   Reply With Quote
Old 03-09-2014, 03:50 PM   #4
gen3usa
gen3usa's Avatar
one thing i noticed since buying is the temp gauge has always looked to read low, it doesn't sit up by the 200* mark
1985 Silverado C20
454 Gas Hog
74K miles no crust!
Old 03-09-2014, 03:55 PM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
My first two items. Fuel pump and ignition module. Ignition modules act funny when they get hot. Have it tested for free at a parts store.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 03-09-2014, 03:58 PM   #6
gen3usa
gen3usa's Avatar
pardon my ignorance, is the ignition module something i can take into them for checking, as the truck itself is capable to take in? also, do these trucks with dual tanks have in tank fuel pumps? or one man pump and a tank divert valve?
1985 Silverado C20
454 Gas Hog
74K miles no crust!
Old 03-09-2014, 04:01 PM   #7
gen3usa
gen3usa's Avatar
assuming the module is under the Dist Cap?
1985 Silverado C20
454 Gas Hog
74K miles no crust!
Old 03-09-2014, 05:26 PM   #8
gchemist
gchemist's Avatar
Yes, the ignition module is under the cap. You have remove it.
Looks something like this: http://www.gasgoo.com/auto-products/...407/15832.html
Coat it with die electric grease before installing it back.
Only TBI and fuel injected trucks have in tank pumps.
The fuel pump is on the passenger forward side of the engine.
Another common problem is the Electronic Spark Control (ESC) module. Read about it here on how to troubleshoot it and bypass it.
http://www.73-87.com/7387garage/drivetrain/escrepl.htm
Old 03-09-2014, 09:15 PM   #9
mrolds88
What about the fuel filter or the fuel sock in the tank?
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 03-10-2014, 07:02 AM   #10
gchemist
gchemist's Avatar
The fuel filter is up on the carb. Just follow the fuel line. Carefully remove the line from the carb. The filter is about 1" long. The filter goes in only one way. It has one end with a rubber end.
Old 03-10-2014, 10:33 AM   #11
ddr11
ddr11's Avatar
I'm gonna take a shot in another direction. when you first start it cold it runs fine for about 20 minutes if I read your post correct, so after the motor comes up to temp is when the problem starts. This is just a suggestion crank it and let it just idle until the temp starts to come up take a can of starting fluid and shoot it around where the intake mates to the heads if and when the engine shuts off you have found your problem. Intake leaks always cause backfiring and usually are more profound once the heat in the motor gets up. Your heading sez 85 454 w/74k original you may just need to snug some intake bolts!
ddr11 is offline   Reply With Quote
Old 03-10-2014, 12:06 PM   #12
GRADYS Performance
GRADYS Performance's Avatar
Fuel pumps on the mid 80s big blocks have been known to fail on a regular basis. Good chance that is your problem. I have a late 85 454 and have had 2 pumps on it in under 100K.
GRADYS Performance is offline   Reply With Quote
Old 03-11-2014, 02:36 PM   #13
gen3usa
gen3usa's Avatar
Thanks for such quick help you all. As always the forum family strikes again for some help. Shes back on the road and no failures since replacing the ICM, took about 30 min and I was out cruising to see if it was fixed, so far so good. Thank you all so much.
1985 Silverado C20
454 Gas Hog
74K miles no crust!
