Old 03-09-2014, 06:10 PM   #1
uxdesigner
2000 5.3 Vortec w/ 4l60e Wiring Help
Anyone know what the relay in my wiring is for? Do I need it? Have I identified the sensors correctly? Do I just need the MAF and (1) 02 Sensor from this leg?
Specs:
2000 5.3 Vortec w/ 4l60e Wiring Harness
uxdesigner is offline   Reply With Quote
Old 03-10-2014, 07:02 AM   #2
dec010974
dec010974's Avatar
Re: 2000 5.3 Vortec w/ 4l60e Wiring Help
Hello uxdedigner. I don't recall ever seeing a relay wired in a harness like that. From you pics, I can't make out what is. I would need a close up pic. To answer your question, no you don't need it in your harness if it is a relay. Most lsx swap guys wire our relays in stand alone fashion. Also, to answer you next question you only need (1) set of o2 sensors which means you will have (2) o2 sensors, one for each side, driver o2 and passenger o2. Yes, you will need only the MAF sensor from that side. I can't tell on your pics but that egr may be the throttle body plug such as idle air controller. There should be a throttle position plug me t to it. I wanted to see the other injector/ coil pack side to see if this is the idle air controller. I hope this helps. Clark.
dec010974 is offline   Reply With Quote
Old 03-11-2014, 02:27 AM   #3
uxdesigner
Clark, thanks for the info. Just what I was looking for and yes that was the EGR with the IAC on the other side as you mentioned.
Old 03-10-2014, 07:25 AM   #4
chuckmc8
It's alsways something.....
chuckmc8's Avatar
You COULD pop the covering off the wires and trace it back to the computer connector and the number on the computer will tell its function. Just use the chart at LT1Swap.com to figure it out. HTH
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 03-11-2014, 02:30 AM   #5
uxdesigner
I also traced the wire back to PCM from the relay and it turns out to be the AIR Pump Relay Control (w/NC1) which is not needed and I've gone ahead and pulled it. I've also not seen this in any of the wire how to's
Old 03-11-2014, 03:42 AM   #6
ls1nova71
ls1nova71's Avatar
NC1 is california emmisions code for older engines, I believe they stoped using it around 2001 or when they took the egr valve away. I've personally never seen one in a harness like that though, all the wiring diagrams I have say that relay is in a fuse box.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
