Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 03-10-2014, 10:45 PM   #1
tkeduk8r
tkeduk8r's Avatar
73-82 Chevy truck tilt w/cruise and key
Still going through some things and have this extra tilt column. It is tight, has the key, and functional cruise control stalk. This is correct for a 73 thru 82 but should work for a 83-87 with some minor wiring mods..... paint is nice as well as the chrome.... $145 shipped to lower 48.... first I'll take it....
Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 03-11-2014, 02:31 PM   #2
qksilver
Re: 73-82 Chevy truck tilt w/cruise and key
How do you make it work for the 83-87, the wiper stuff is on the stalk. I don't have a place on my dash (86) like my 78
Thanks,
Steve
qksilver is offline   Reply With Quote
Old 03-11-2014, 05:29 PM   #3
tkeduk8r
tkeduk8r's Avatar
Actually I went out and compared it to a column in my students 85 and I forgot about the high beam, wipers and cruise in the turn signal stalk. Looks like the whole upper housing is different and therfore wuld not be a "minor" wiring job.... the column for sale would be able to replace any up through 83, but if i recall pre-78 had the same connector to the cab harness but the pin position is a bit different. Thats why I took the pigtails out and included them so the new owner can reposition the pins (10 minute job) to fit their application. Thanks for pointing that out!!!
--Mike
Old 03-11-2014, 05:20 PM   #4
DownLowHoe
DownLowHoe's Avatar
I'll take it if qksilver passes.
DownLowHoe is offline   Reply With Quote
Old 03-11-2014, 05:57 PM   #5
1774btcrew
1774btcrew's Avatar
The shaft on the bottom of the column is also different. 73-78 had a splined lower shaft, 79-83 had a double D lower shaft. Not a problem as long as you have the correct intermediate shaft for the column
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 03-11-2014, 05:58 PM   #6
1774btcrew
1774btcrew's Avatar
Assuming a whole bunch of stuff hasn't been changed on the column I would say it is a 79-83 looking at the parts on it without seeing the bottom. Great price on this by the way!
Old 03-11-2014, 08:12 PM   #7
tkeduk8r
tkeduk8r's Avatar
Thank you... hopefully it will find a home in someone's truck vs my basement!
Mike
Old 03-11-2014, 09:25 PM   #8
qksilver
I wasn't sure about a simple wiring......NP, I can't use it
Thanks,
Steve
Old 03-11-2014, 11:39 PM   #9
1774btcrew
1774btcrew's Avatar
Thanks,
Steve
What year is your truck? I build a lot of these columns and 83 and earlier use the same wiring. 1984 and up just have extra wiring for the dimmer and wipers being on the column.
Old 03-12-2014, 09:45 AM   #10
DownLowHoe
DownLowHoe's Avatar
Send me a message with payment info. I'll take it.
Thanks,
Jeff
Old 03-12-2014, 01:44 PM   #11
tkeduk8r
tkeduk8r's Avatar
sent pm!
--Mike
Old 03-13-2014, 12:37 PM   #12
DownLowHoe
DownLowHoe's Avatar
Payment sent. Thanks!
