Old 03-12-2014, 11:54 PM   #1
77chevyinline6
77chevyinline6's Avatar
Unhappy Someone please point me in the right direction.
My truck came origonal with a saginaw 3 speed (on the tree) and a 250l6, it got swapped for a Built up 350 and went through 2 saginaws, took the 350 out and i am in the process of putting the l6 back in. BUT, i dont have a transmission. i was given a th200 or 200 metric. will this setup be okay? how will it bolt up and perform? This truck has literally burned a hole in my pocket but it means too much to me to get rid of. and what about a shifter for the automatic? Please help me guys lol. And a pic of my engine, just to share.
77 c10 (went from a inline 6 to 350) (converted to 3 speed in the floor)
350: mild cam, holley 600cfm 4bbl, summit stage 1 intake, accel billet distributer, flowtech headers, 2 1/4" exhaust with glasspacks, powermaster 160a alternator.
77chevyinline6 is offline   Reply With Quote
Old 03-13-2014, 01:27 AM   #2
cool68
Re: Someone please point me in the right direction.
try asking at phoenixtrans.com and bowtieoverdrives.com also, to help figure out engine RPM search for calculator at project33.com
cool68 is offline   Reply With Quote
Old 03-13-2014, 02:08 AM   #3
thefraze_1020
thefraze_1020's Avatar
Take a hunt around on this website. There are some useful articles.
https://www.novak-adapt.com/knowledg...shift_info.htm
Cameron
1984 Chevy C20 Custom Deluxe
thefraze_1020 is offline   Reply With Quote
Old 03-13-2014, 02:23 AM   #4
77chevyinline6
thanks guys, i just wonder how much trouble a t5 swap would be...
Old 03-13-2014, 06:10 AM   #5
D13
D13's Avatar
200C is a light duty transmission not really designed for a truck. You can use it for a while. It may require driveshaft length change. You MUST wire up the converter or it will get hot. A factory automatic column can be adapted, or a floor shifter.
3 speeds are cheap here. Cost more for a clutch LOL. There are several T5 swaps, biggest issue seems to be getting a WC T5 and relocating the shift tower.
Might check the j-yards for a Saginaw 4-speed too.
If you're goign to go auto, TH350's are stil plentiful and relatively inexpensive, and 700's can be had reasonable. I occasionally wil run accross a 2004R (think olds powered caprices out of the late 80's, or Monte Carlo's).
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 03-16-2014, 02:51 PM   #6
77chevyinline6
thanks for the help guys i really appreciate it. but i ended up going to a huge junkyard in king and pulling another 3 speed saginaw for 225$ does anyone know the size and length of the flywheel to crank bolts?
