Old 03-13-2014, 10:31 AM   #1
harrydunn
harrydunn's Avatar
New Dash Pad Installation
Got the old one off. It wasn't too bad. It was brittle so I ripped all of the padding off first, used tin snips to cut the metal strip around each threaded post and then just pulled up on them with enough tension to spin the nut free. Much easier than trying to get a tool up in there. The new one as you can see will need to be painted. Using SEM flexible medium parchment. Seems to be the best match I can find. We shall see. Fun little project so far. The interior is just about complete and ready for show season (it's only been to one car show in 42 years!) with the new steering wheel and dash pad. I need to get a new rubber floor cover and I'm good to go. I'll post some more photos of my progress over the new few days as I get it painted and installed.
1972 GMC 2500 Custom, 96K miles, Purchased New By My Grandparents
2016 Toyota Tundra TRD Off-Road SR5
1993/2003/2005 Toyota Land Cruisers
2004 Corvette Z06 / 2000 Covette Coupe
2006 Ducati Multistrada
2014 BMW X3 XDrive35i M Sport
harrydunn is offline   Reply With Quote
Old 03-13-2014, 04:09 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: New Dash Pad Installation
Looking good!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-13-2014, 08:38 PM   #3
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
1/4" drive flex extension on a thin wall, medium deep well socket in 5/16 or 3/8 (Cant remember wich size) socket will make installing that new pad quite a bit easier...Dash pads are among the top five PITA parts to R&R..."Seven screws with seven different obstructions!"
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 03-13-2014, 08:55 PM   #4
leddzepp
Moderator
leddzepp's Avatar
Do NOT over tighten the attaching nuts or you will end up with a warped and wavey dash pad. Finger tight only.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 03-13-2014, 11:52 PM   #5
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
REALLY good advice. I tightened mine too tight and then figured out the "error of my ways" later. I can't get the waves out of the pad. It's just enough that *I* notice it. Which makes it bad (pad?) enough.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 03-14-2014, 12:59 AM   #6
texjake
texjake's Avatar
Good thing I found this out before installing my new dash. Finger tighten only huh? Wouldn't maybe some blue Loctite be advisable to keep the nuts from vibrating and backing off since its a pain in the arse to get to those nuts? Or even maybe some nylon nuts? I've got some of that new blue Loctite QuickStix to try & I think that's where I'm going to use it on the threads of the bolts on the dash pad.
"Now all I need is a shop to go with my shop vac!"
texjake is offline   Reply With Quote
Old 03-14-2014, 12:27 AM   #7
SS Tim
SS Tim's Avatar
Are you actually planning on a white dash pad?
SS Tim is offline   Reply With Quote
Old 03-14-2014, 09:43 AM   #8
harrydunn
harrydunn's Avatar
Got it all done. The SEM product did not quite match so I ended up spraying with some custom-mixed vinyl paint from a few months ago. Matches great and the install was not too bad. I'm 6'-5" with large hands so I'm pretty scraped up this morning from working under the dash. Very pleased with the results.
Some photos:
Ready for the new one.
Literally ripped the old pad out and was able to bust the hard-to-get-to nuts loose too.
Adhesion Promoter is a must. You can see I chose the wrong color of the SEM product. My fault, no their's.
Safety first, kids! I was spraying in the concrete "bunker" under our garage. Zero ventilation.
Out-of-the-box color was a dark brown but as close as I could find to start with.
Final result. Couldn't be happier.
Old 03-14-2014, 10:17 AM   #9
Stickman
Stickman's Avatar
Looks Good
Stickman is offline   Reply With Quote
Old 03-14-2014, 12:33 PM   #10
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looks very nice
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
