Old 07-25-2003, 08:37 AM   #1
smokekiki
Mike
smokekiki's Avatar
Distributer help
I am getting ready to pull the hei in my sub to clean and to put a new vac advance on.With the pointer on tdc and #1 cyl on tdc on compression stroke,the rotor is pointed at the #2 plug tower.The previous owner has the #1 plug wire on the #2 plug tower.Every wire is off by one.Can I just put the distributer in it's proper location and move the wires?
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 07-25-2003, 08:51 AM   #2
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
If you're going to pull it to do other work, it's probably a good idea to put it back in right. Your biggest problem will be getting the dizzy to drop back in after you rotate it to the right point. The oil pump shaft won't line up. The best way I've found to get it to drop is to rotate the engine with a breakover bar on the crankshaft, or by turning the engine over by hand, until the dizzy drops in place. This is much easier with the plugs out though.
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
Old 07-25-2003, 11:33 AM   #3
oldsub86
The simple answer is yes. You can move the wires around the cap so long as you have them in the correct firing order.
1968 Chevy - 292 with a powerglide
oldsub86 is offline   Reply With Quote
