Old 07-25-2003, 10:30 AM   #1
Linus0014
Guest
Posts: n/a
Ball Joints
I'm replacing the upper and lower ball joints on my 72 GMC c-15 1/2. The new upper ball joint is held in by a 2-3'' snap ring, instead of the 4 bolts that replaces the rivets that I drill out with the old one. Should I use this one I have with the snap ring or take it back and try to find the one with the 4 bolts? Oversized is when the old ball joint makes a bigger groove and a larger width ball joint needs to go in to take up the worn out space, correct? Because they asked me if I needed oversized and I said no...THanks for the help.....
Old 07-25-2003, 12:19 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
They gave you the wrong ball joint.
The original was held in by the rivets, and the replacement is held in by bolts. No snap rings hold them in.
Tx Firefighter is offline   Reply With Quote
Old 07-25-2003, 12:41 PM   #3
COBALT
COBALT's Avatar
I second that!
Given the way the A-arms are designed there's no way a "snap-ring" ball joint would be stable enough to maintain geometric integrity.
Time to take it back to the store.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 07-25-2003, 12:54 PM   #4
rickspickuppart
Take it back
rickspickuppart is offline   Reply With Quote
Old 07-25-2003, 08:48 PM   #5
Terry S
I think that you've got the wrong upper as well. I've never seen an upper ball joint for these trucks that didn't bolt in. As for the lower one, those just press in and over the years, the hole in the a arm has a tendency to "wallow out" to the point that a new ball joint won't press into the hole with a snug fit. Try the new stock one, and if you can shove it into place with just your bare hands, then the hole is too big and you need to take it back and trade up to an oversized one.
In either case, when you're pressing the new one in, the easiest way that I've found is to raise the truck by the front cross member or frame, then when you have the new one started, come up from underneath it with a piece of wood on a floor jack. When you've got some tension on the floor jack (and you're sure that the ball joint is still sitting straight in the hole) encourage it into place by tapping down on the a-arm all around the joint with a hammer. Note; you have to do this before you install the grease zerk so as not to break it off
I can do all things thru Christ, but he evidently doesn't want me to beat that Camaro light to light....
Terry S is offline   Reply With Quote
Old 07-25-2003, 10:38 PM   #6
Linus0014
Guest
Posts: n/a
I took them back and they can't even order anything else. I'd rather buy them from the boardmembers, but had to go to napa b/c the truck was apart at the time.
Old 07-26-2003, 08:18 PM   #7
Terry S
Personally, I'd go to AutoZone or O'reilly. They've never let me down on suspension parts.
Old 07-26-2003, 09:12 PM   #8
Linus0014
Guest
Posts: n/a
I actually got the parts rom Autozone.
