07-25-2003, 11:18 AM | #1 |
ready to start rebuild
OK......just completed installing my rebuilt 327. being the first engine i have completely built myself, i have to admit i'm a little freaked out about starting it. cripes, i hope i got everything right! i followed 'rebuilding your chevy small block' to the T, so i'm hoping it will go smoothly. any last minute suggestions? during the rebuild i converted over to HEI and one point i'm a little blurry on is setting the timing during cam break-in. i assume that the 8 degrees BTDC setting is at idle. how do i set this when i can't let the engine get below 2000 rpm during cam break-in? should i wait to set the timing after the 20 minutes on the cam is up? just looking for a little last minute encouragement.
07-25-2003, 12:08 PM | #2 |
We set the timing as close as we can get it before firing up the engine and then run in the cam before final adjustment. Sometimes it is hard to get a new engine to idle down and you have to play with them, (Murphy is helping you usually), so you don't have to be in a hurry to set the timing as long as it is close.
Did you spin up your oil pump before installing the distributor? Good luck! Jim |
07-25-2003, 12:20 PM | #3 |
i did prime the oil pump using my drill and a mr gasket priming shaft a couple of days ago. i primed it for a couple of minutes. one odd detail i observed during this exercise......oil flowed freely out of all of the left side rockers but none on the right side. i'm assuming this is because the crank and/or cam was not turing and the oil galleys were not ever lined up?
07-25-2003, 12:21 PM | #4 |
bucket, guit skaking-everything will go alright. To set your time before starting just bring your timing mark around to 8-10 BTDC and stop there. Make a mark on dist. base where # 1 plug wire is. Remove cap and move dist. so rotor lines up with this mark. This will be close enough for break in. Good luck amd guit that skaking. lol
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
07-25-2003, 12:23 PM | #5 |
Right on oil issue--just turn motor 180* and prime again.
07-25-2003, 12:29 PM | #6 |
thanks fellas! i'm feeling more confident now
as usual, I'm probably over-thinking everything. |
