Old 03-15-2014, 09:42 PM   #1
Mr.Hyde
Lwb cross sills (help!)
Well it's getting late here I don't wanna leave a job half finished so here's the big question on the longbed there should be 5 large cross sills and I only see enough bolt holes for 4 and I guess the small support sill. Where is this goth cross sill near the rear supposed to be they are the number 3 sills according to the lmc catalog but give no further help. If I had my computer not accross the city I would research it but if I could get some quick help?
1968 Chevy C10 build - http://67-72chevytrucks.com/vboard/s...d.php?t=546713
Member of tailgate association of manitoba
Mr.Hyde is offline   Reply With Quote
Old 03-15-2014, 09:58 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Lwb cross sills (help!)
Wood bed floor or steel?
LockDoc
Leon
Old 03-15-2014, 10:02 PM   #3
Mr.Hyde
Wood bed it's a 1968
Old 03-15-2014, 10:07 PM   #4
LockDoc
LockDoc's Avatar
There are some pictures in this thread....
http://67-72chevytrucks.com/vboard/s....php?p=6410882
Not sure how much it will help.
LockDoc
Leon
Old 03-15-2014, 10:09 PM   #5
LockDoc
LockDoc's Avatar
Here's another.
http://67-72chevytrucks.com/vboard/s....php?p=4005717
LockDoc
Leon
Old 03-15-2014, 10:16 PM   #6
Mr.Hyde
Looks like the rear most is free floating. I am making these cros sills from scratc so you can see why I am gonna need all the help I can get :/
Old 03-16-2014, 12:01 AM   #7
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
Maybe this will help for locations.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 03-16-2014, 02:05 AM   #8
Mr.Hyde
Do you have in relation to the frame?
Old 03-16-2014, 02:35 AM   #9
FirstOwner69
FirstOwner69's Avatar
Try this link.
http://67-72chevytrucks.com/vboard/s...d.php?t=581185
And... from Mar-K
"The first cross sill connects to the second bed strip hole that is 3-3/8 inches back from the front of the bed. The second cross sill connects to the third bed strip hole that is 15-3/8 inches back from the front. The third cross sill attaches to the bed strip hole 26-3/4 inches from the front of the bed. The fourth cross sill connects to the eighth bed strip hole at 72-1/2 inches from the front, which coincides with the rear of the wheel well. The fifth cross sill connects to the ninth bed strip hole at 83 inches from the front. There are two smaller cross members located at the front or beginning of the wheel well and at 60-1/8 inches from the front of the bed. One reinforcement strip is 72” and one is 49-1/2”. Attach these reinforcement strips to the bolts from the bed sides and the wheel well. Mount the 72” at the front of the wheel well and the 49-1/2” reinforcement strip fits between the wheelhouses at 60-1/8 inches."
FirstOwner69 is offline   Reply With Quote
Old 10-16-2017, 10:01 PM   #10
59 fleet
Originally Posted by FirstOwner69 View Post
Try this link.
And... from Mar-K
"There are two smaller cross members located at the front or beginning of the wheel well and at 60-1/8 inches from the front of the bed. One reinforcement strip is 72” and one is 49-1/2”. Attach these reinforcement strips to the bolts from the bed sides and the wheel well. Mount the 72” at the front of the wheel well and the 49-1/2” reinforcement strip fits between the wheelhouses at 60-1/8 inches."
That 49-1/2" reinforcing strip is 60-1/8 from the bed front. That should line up with one of the holes in your wheel tubs and with a hole in the bed strips.
59 fleet is offline   Reply With Quote
Old 10-16-2017, 10:31 PM   #11
crakarjax
crakarjax's Avatar
Thanks! Just what I needed to know.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 03-16-2014, 03:09 AM   #12
Mr.Hyde
kind of since youve been through this recently i believe its these two sills no sure if they are bolted to the frame being there are no holes i will have pictures of my project on my build thread shortly.
Old 03-16-2014, 03:18 AM   #13
Mr.Hyde
I did not realize there are 2 reinforcement strips, i circled the 2 i need info on so ill continue to research and look things up but it doesnt look like i have a second set of holes on the rear end for another rear sill.
Old 03-16-2014, 04:05 AM   #14
FirstOwner69
There is only one reinforcement strip shown in the picture of mine above that you copied from the other thread. My truck never had the 2nd one that Mar-K said I should have had. The only cross sills that get bolted to the frame are those at 3-3/8" (1st), 26-3/4" (3rd), and 72-1/2" (4th) from the front. The rear cross sill bolted and welded to the bed sides also gets bolted to the frame through the brackets welded to it. As I recall, the other cross sills (2nd and 5th) and reinforcement strips are only bolted to the metal bed strips and just rest on the frame.
Here is a picture of mine taken at a slightly different angle that better shows the sill and reinforcement strip depths.
Old 10-09-2017, 08:42 PM   #15
crakarjax
crakarjax's Avatar
Diging this up... it looks like there should be a short cross brace going between the wheel wells, otherwise there's a large unsupported area between the 2nd to read cross brace and the high spot on the frame with rivited crossmember.
Was there a brace here from factory and if so, where? I don't see it listed in my catalogs.
Old 10-11-2017, 03:27 PM   #16
crakarjax
crakarjax's Avatar
I found at mar-k "67-72 Fleetside Bed 49.5" Reinforcement Cross Sill With Wood Floor" and I guess this goes at the mid-point of the tubs but I haven't been able to find any pictures to confirm this. There are no frame holes for it so I guess it must just float like the other reinforcing strip?
Old 10-16-2017, 08:29 PM   #17
crakarjax
crakarjax's Avatar
... anybody know? Still haven't been able to find an answer anywhere.
