Old 03-18-2014, 06:38 PM   #1
Fitz
Baby Gets Back..... Tubbing a stepside.
I decided to tub my stepside using fleetside wheelhouses. The first photo shows the distance between the frame and the bedside. That makes the width of the wheelhouse 6-1/2 inches. Using masking tape, I marked the cuts to get that width and cut them with a 3 in grinder and a cutoff wheel. After scribing the halves so that there was no gaps I Tack welded with a MIG, then finish welded the tubs with a TIG. A little Grinding and surfacer got them ready for priming. That's one day. More to follow.
Fitz is offline   Reply With Quote
Old 03-18-2014, 07:59 PM   #2
darkhorse970
darkhorse970's Avatar
Re: Baby Gets Back..... Tubbing a stepside.
Cool, I am following along. I'm going to mini-tub my stepper too.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 03-19-2014, 05:43 PM   #3
Fitz
Primered and prepped for finish paint.
Old 03-19-2014, 07:33 PM   #4
slow-1
slow-1's Avatar
Is your shop in your dining room or do you just have a really fancy garage.
Nice work on the tubs so far.
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline   Reply With Quote
Old 03-19-2014, 09:34 PM   #5
ole dollor
ole dollor's Avatar
LOL.... that is a nice shop...
ole dollor is offline   Reply With Quote
Old 03-20-2014, 10:14 AM   #6
BugzC10
BugzC10's Avatar
It can't be that hot in Tucson yet to start working in the house.
You should start selling them...nice work!
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 03-20-2014, 10:06 PM   #7
Fitz
Originally Posted by BugzC10 View Post
It can't be that in Tucson yet to start working in the house.
Why turn a great hobby into a...J O B? And no, it's not cold in Tucson but there is a lot of stuff in my shop.
Old 03-20-2014, 10:04 PM   #8
Fitz
I always shoot pictures in my dining room. Don't you?
Old 07-20-2014, 09:48 AM   #9
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
You must be single.
Tom Vogel is offline   Reply With Quote
Old 07-20-2014, 01:06 AM   #10
SierraMtns
SierraMtns's Avatar
Any updates? You have any pictures of the bed tub?
SierraMtns is offline   Reply With Quote
Old 12-10-2014, 02:54 AM   #11
SierraMtns
SierraMtns's Avatar
Hey Fitz, Any pictures of the finished bed?
Old 12-10-2014, 04:30 PM   #12
Fitz
Not yet! Still playing with my LS2 powered rice burner. But....I do have the silver paint for the tubs. I'll post bed pics next week. Then pics on how to shorten a 12 bolt axle. Mittler Bros just delivered the tools for that!
Old 12-10-2014, 05:37 PM   #13
SierraMtns
SierraMtns's Avatar
I bet that Miata is a kick in the pants to drive.
Old 12-12-2014, 11:50 AM   #14
joey8383
joey8383's Avatar
In for the pics. Nice work. How many projects do you have going on in there?
joey8383 is offline   Reply With Quote
Old 12-12-2014, 01:02 PM   #15
Fitz
Just two. A V8 Miata which is within a month or so of complete and a stretched chopper built on an Independent Cycle Low Life frame.
The truck was finished but it does need room for larger tires so, I built the tubs and have them ready to go. It's about a day to get the bedsides and the deck cut and the tubs in. Then I shorten the diff and Voila! Room for M&H 345/35 R18's under a C10.
Old 12-12-2014, 03:41 PM   #16
Fitz
I thought this topic was just Ho Hum but I guess not. Soi, this morning I cut the bedsides, drilled for the mounting holes and got one side ready to trim the bed boards. I used two templates, one for the cut and the other to drill fodr the mounting bolts for the tubs. They are the same dimensions front to back so there are no lefts and rights. Using a plumb bob centers the cutting template in the wheel well then two reference holes are drilled. To locate the template on the inside of the bed. Once the cutline is marked put the drill template over the cut template and drill pilot holes for the tub mounting bolts. Then, get up your courage and a three inch grinder with a cutoff wheel and make the hole. Remember, the inside of the tub has a flange that wraps around the edge of the hole you are cutting in the bedside so we aren't trying to maintain real close tolerances on the cut but don't be sloppy either. It took two hours for one side this morning, so this is something that can be done in a day.
Old 12-12-2014, 03:43 PM   #17
Fitz
Drilling and cutting takes a bit of time but with a little care the result is nice! I still need to clean up the front edge of the bedside where it meets the tub and mark and cut the bed boards and the stainless strips but you get the idea. It's hare to get a good pic of the inside of the tub where it wraps around the cut but here's a try.
Old 12-12-2014, 06:50 PM   #18
Mike C
Mike C's Avatar
Nice work!
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-12-2014, 07:09 PM   #19
68racer
Yeah baby!
68racer's Avatar
Like the work. Have you ever noticed that stepside fenders are narrower than the cab? I widened my stepside to get wider tires in. I put an inch and a quarter in each side and now the doors and rear fenders are in line. Looks better and gets bigger meats in.
11.37 @116
68racer is offline   Reply With Quote
Old 12-13-2014, 07:39 AM   #20
Fitz
Widening the fenders does look good when they match the doors but that long, compound curve is tough to get right without an English wheel. My hat is off to you if you pulled that off! It is not something I could have gotten right.
While it is a dodge, adding tubs inside the bed is much easier as the tub curves in one direction only and I can get a 20 inch section width tire in there. This is the look I am after:
Old 12-15-2014, 04:15 PM   #21
SierraMtns
SierraMtns's Avatar
Man those are some fatties...
Did you cut the wood to be flush with the frame?
Great job.
Old 12-15-2014, 11:09 PM   #22
Fitz
Great job.
Yes. The frame steps out at the spring perch but the wood and stainless strips have been trimmed so the frame is the limiting factor on tire width. That opening now supports a 20 inch section width tire....but no one makes a tire that big!
Old 12-13-2014, 09:29 AM   #23
68racer
Yeah baby!
68racer's Avatar
I've not made myself clear. I may be English but I don't have an english wheel! What I did was widen the bed. I added sections to the front panel, added extensions to the under bed supports and added a return at the rear so that the tailgate is stock width. I see 67-72 Pro Street stepside trucks that have a wider front track than rear and it doesn't look right to me.
11.37 @116
Old 12-13-2014, 09:41 AM   #24
volksworld
68 racer,now you've got me thinking....i've got leaf springs so i cant go into the bed...so the bed is 2 1/2 wider?
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
Old 12-13-2014, 11:17 AM   #25
Fitz
Brilliant! I never thought of that.
