Which panhard bar?
I'm bagging the rear of my 63 on the factory trailing arms in the springs factory location,2" blocks (maybe), and a c notch. Just wondering what the best panhard bar and shock relocators kit will be best? I like the no limit shock kit but I want to try and keep it all ordered from the same place. Thanks guys!!
![]() Join Date: Jan 2011
Re: Which panhard bar?
For a panhard bar I like the long ones. I have my 65 bagged and have the short stock length bar on it and the rear moves a god bit through full travel. I plan on changing it out o the long bar to reduce the side to side movement. CPP, Porterbuilt, No limit all make good stuff you just got to pick the one you feel suits your build the best.
JImmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Porterbuilt or NoLimit for long/adjustable Panhard bars & relocated shock mounts.
Both the PB and NoLimit are good choices. We have the PB in stock, but would have to order in the shock relocators for you.
- Travis http://www.azproperformance.com/63-7...c-Bar-Kit.html ![]() |
I'm glad to see that picture answers all my questions!! You still have one in stock??
63 knee knocker Porterbuilt,Ls 5.3,smoothies. "Getcha' pull" **signature space is not a classified section, thank you** |
Glad it helped... Yep, I sure do have one in stock right now.
Hold tight ill order it right after dinner!
