Old 03-20-2014, 12:03 PM   #1
chris989
400 turbo shift 2nd to 3rd gear
Hello All,
I have a 400 turbo, 5.7 TBI, 4wd. The truck is finally running very well but i still get stuck between gears.
If i am accelerating very lightly, the transmission will jump back and forth between 2nd and 3rd gear. If i let off the gas or accelerate it will pick a gear and continue on fine. It is only when light on the pedal.
I have replaced the module and vacuum line and can not detect any leaks anywhere. Could this be something inside the trans or a symptom of a bigger issue to come?
thank you,
Chris
chris989 is offline   Reply With Quote
Old 03-20-2014, 12:07 PM   #2
willett
Another Day, Another Dollar
willett's Avatar
Re: 400 turbo shift 2nd to 3rd gear
Interested to hear an answer. Mine does thy occasionally too. Mines had a rebuild within the last 10,000 Km's
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 03-20-2014, 02:14 PM   #3
chris989
I can't confirm how many miles on mine, I am guessing a few, but it shift perfect and strong as long as i keep my foot in the gas. I installed an adjustable module and it made no difference. I am putting the vacuum gauge on and trying to drive. see it the vacuum jump around
Old 03-20-2014, 06:16 PM   #4
Greenlee
Greenlee's Avatar
My first thought was vacuum problem also. Do you have the factory metal line with short rubber hose on each end? I read somewhere that you shouldn't use rubber hose for the entire length from the transmission to the engine. Not sure if it makes a difference of not. I put a TH400 in my truck and was lucky enough to find a factory metal line.
Greenlee is offline   Reply With Quote
Old 03-20-2014, 06:17 PM   #5
chris989
I have the metal line and both ends have fresh rubber.
Old 03-20-2014, 06:34 PM   #6
ont_guy_38
ont_guy_38's Avatar
Could possibly be the governor is worn out or stuck. The plastic gear is known for getting stripped and then not shifting correctly. I had a similar problem once, turned out i had changed my carb and the linkage wasn't correct so so the throttle was being pushed so far it was setting off the downshift switch on the pedal.
1985 C10
2004 Avalanche
ont_guy_38 is offline   Reply With Quote
Old 03-21-2014, 12:16 AM   #7
chris989
This is a 400,, i think the OD trans had a cable linked to the carb.
Old 03-20-2014, 06:35 PM   #8
clapage6
hmmm do you get this same 2nd + 3rd gear hunting at any MPH? and it will do it consistently until you change throttle position?
clapage6 is offline   Reply With Quote
Old 03-21-2014, 12:15 AM   #9
chris989
I mostly notice it around 30-40 mph. I can do it higher but at that point my foot in normally in the gas.
When i give it some gas and drop the vacuum it will go to second. then I just give it enough gas to run the RPM higher, get to my speed and then let off.
Old 03-21-2014, 02:02 AM   #10
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
I have a friend and that is what his th400 does also but never looked into it. I would say it wouldn't hurt to take a look at the governor. Make sure the shuttle can move freely and is clean. Also check the governorgear to make sure iit's not worn out. They typically wear out in the center making an hour glass shape.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 03-21-2014, 03:01 AM   #11
MylilBowTie
Right turn Clyde
Old 03-21-2014, 11:50 AM   #12
chris989
I confess, I have only put a shift kit in a few turbo 350s back in the day and I have no idea where that thing goes. I will look into it, it is a big PIA to replace the gear?
Chris
Old 03-21-2014, 11:49 AM   #13
clapage6
imo, unlikely it is the governor but could check it to be sure... all mine just wouldn't shift down to first at a stop when it was stuck.
The modulator tends to be the one that manages when to shift to a gear and how long to hold a gear, so if fluid is good and not burnt you may just keep playing with that adjustable modulator and also make sure it is indeed free and moves smoothly...
I'm pretty sure your th400 SHOULD have a kickdown switch.. it's not the th350 style with a cable. It's just a wire supplying 12v when the pedal is to the floor or usually 3/4+throttle anyway, could be something to look into or bypass for testing purposes... whether or not it is still wired is a good question, plenty of people leave them off and plan to manually down shift when needed.
Old 03-21-2014, 12:13 PM   #14
clapage6
no problem at all to replace that gear if needed,
4 bolts to the cover on passenger side of trans, slide the governor out, remove old gear from the shuttle if it's still there haha..
slide the new one on and gently replace governor into trans done
Old 03-21-2014, 02:38 PM   #15
chris989
Anyone have a part number or source from a local type place. All i see is for ordering online? I would like to pick it up at a parts store and try it this weekend.
Chris
Old 04-03-2014, 10:51 PM   #16
WyattEarp18
WyattEarp18's Avatar
Sounds like its losing pressure once it hits third. Might check the trans fluid pump.
'79 K20 Camper Deluxe
'99 F-250 PowerStroke
'98 Z71 4x4
Some people are like slinkies, good for nothing but make you laugh when tossed down a flight of stairs.
WyattEarp18 is offline   Reply With Quote
Old 04-05-2014, 07:27 AM   #17
Greenlee
Greenlee's Avatar
Don't really have anything new to add. Just want to point out that on TBI trucks there is not a kickdown switch behind the gas peddle like there is on older th400 vehicles. Kick down on TBI trucks is controlled by a signal from the computer and a relay mounted on the firewall next to the fuel pump relay. I don't think the kick down switch is your problem because it only engages at lower speeds. On my truck it only kicks down at around 25 mph. The shifts at higher speeds are controlled by the vacuum modulator.
Old 04-05-2014, 10:42 AM   #18
GRADYS Performance
GRADYS Performance's Avatar
Check your Line Pressure with a Guage.
GRADYS Performance is offline   Reply With Quote
Old 04-05-2014, 11:59 AM   #19
chris989
update,
THe governor gear was in perfect shape, reinstalled the old one and my problem still persist.
Greenlee, I have a TBI turbo 400 set up. I d not think there is anything electronic controlling this transmission, But then again, I have not scoured the casing. I believe there is only the vacuum module.
Grady. I will find some fittings and tap into the cooling line. Is this something i can test sitting stil with engine RPM or do i need to be under a load any driving?
Thanks everyone.
Old 04-05-2014, 03:22 PM   #20
GRADYS Performance
Line pressure is taken at the 1/8" pipe thread port that has a plug in it. It located on the side of the transmission in the middle of the case. It is the only pipe plug in the case. The cooler lines are not for Line Pressure readings. You check the pressure in each gear at idle and with the rpm raised.
Old 04-05-2014, 04:33 PM   #21
imjeff
imjeff's Avatar
The newer TBI 400s us a 12 volt signal from the computer that originates from the throttle position sensor. You can use the older throttle pedal switches or newer stuff like lokar's. The kick down switch is a WOT function, not a low speed function. Unless yours is sensing WOT somehow, it's not the kick down switch. Sounds like a fluid/vacuum issue. A shift kit will probably fix this, but if the vacuum/fluid issue is outside the valve body you'll still have the underlying issue. Heat and dirt are the only enemies of an automatic.
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 04-05-2014, 05:23 PM   #22
rexrandom
my '73 has a kickdown switch (electronic) on the passenger side carb linkage. wires into the 400. I'm having problems with the switch/linkage on the carb. B&M makes a $50 kit. That'll be my next move....
rexrandom is offline   Reply With Quote
Old 04-05-2014, 10:20 PM   #23
imjeff
imjeff's Avatar
Lokar makes a cool kit, too, but it's about $70. It is awful perty though.
72 K10 396
75 Cj5 MPI 350 Chev
74 FXE
08 Tahoe
Old 04-05-2014, 10:50 PM   #24
rexrandom
Exclamation Re: 400 turbo shift 2nd to 3rd gear
$70 is their cheap one!
Old 04-07-2014, 03:09 PM   #25
ChevDog1
ChevDog1's Avatar
If you are going to add a kickdown switch, why not just grab a stock one out of the wrecking yard? Your truck should have the mounting bracket for it right next to the gas pedal. I just grabbed one at a swap meet Saturday for $10. It was originally in a GTO, but fits my bracket perfectly.
ChevDog1 is offline   Reply With Quote
