Old 03-24-2014, 10:19 PM   #1
abrahamseven
abrahamseven's Avatar
GMC engine in a Chevy
Ok, I have a 1954 Chevy pickup it has a 1954 GMC Cab and a 248 GMC Engine. I know the front cross member and radiator support is not the same . The 248 GMC Engine is a few inches longer. The front motor mount has been modified. I am now at the point of installing the radiator. My questions is , has anybody on this forum installed a 1954 GMC engine into a 1954 Chevy Pickup? I could use some tips on installing the radiator. Thanks
steven
abrahamseven is offline   Reply With Quote
Old 03-25-2014, 02:15 AM   #2
MARTINSR
MARTINSR's Avatar
Re: GMC engine in a Chevy
I don't have any answers for you but I sure think your truck is awesome!
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 03-25-2014, 10:00 AM   #3
whitedog76
I'm not for sure what's all involved. According to this article, you can use a 235 crank pulley/balancer and then modify your water pump pulley.
I do know that on the 235 water pumps, you can press the pulley mounting hub down shorter. That's how the long water pup 235's are modified for the early trucks.
http://www.chevytrucks.org/tech/gmc302.htm
Looking at my Chevy, you can probably move the radiator to the front side of the support. You may have to do some trimming to the upper suppprt though.
My dad had a GMC powered 3100 back in the 70's and they also put a GMC in one of my grandpa's grain trucks. He doesn't remember how they did it. With him, I'm sure the hot wrench was involved.
whitedog76 is offline   Reply With Quote
Old 03-25-2014, 11:21 AM   #4
OrrieG
OrrieG's Avatar
Might ask over at stovebolts.com too.
Old 03-25-2014, 02:01 PM   #5
mr48chev
mr48chev's Avatar
Does your front crossmember look like this:
which is a GMC crossmember
or does it look like this Chevrolet crossmember?
I'm trying to figure out if you have a GMC engine, cab and box on a Chevy frame or someone has swapped a Chevy nose to a GMC and used a Chevy title with it.
My ongoing truck projects:
Old 03-29-2014, 09:22 AM   #6
abrahamseven
Thanks everybody of the information. And a special thanks to Whitedog for the article, it gives me a better idea of what I am up against . I know it will be a good running GMC/Chevy when I am done. Thanks again.
steven
