Old 03-26-2014, 03:41 PM   #1
Roll'nSlo
Roll'nSlo's Avatar
Front Frame Horns
Long story short I picked up a '66 Chevy C10. The front bumper had 1 bolt and some copper wire holding it on because the bolt holes wouldn't line up. After stripping it down to the frame my suspicion was right. The front frame horns were bent. If possible can anyone post a pic of give me a point of how far back the need to be lined up and set straight? Any help is appreciated.
Roll'nSlo is offline   Reply With Quote
Old 03-26-2014, 03:52 PM   #2
tincan1966
tincan1966's Avatar
Re: Front Frame Horns
Stupid question- but wouldn't the other truck sitting beside this frame be the same?
tincan1966 is offline   Reply With Quote
Old 03-26-2014, 04:05 PM   #3
Roll'nSlo
Roll'nSlo's Avatar
I'm sure it would be but I don't have a straight edge short enough to get in and check the frame. I was looking for a donor cab for that truck when I found the '66.
Old 03-26-2014, 04:20 PM   #4
1963c-10
1963c-10's Avatar
Or measure the holes on the bumper.
Link to thread on frame dimensions: http://67-72chevytrucks.com/vboard/s...d.php?t=325736
1964 Short bed trailer
Old 03-26-2014, 05:31 PM   #5
Roll'nSlo
Roll'nSlo's Avatar
The bumper bolt holes are off, that was my first indication of a bent frame. Thanks for the link, that's what I needed. Now I just need to get CL and start bending.
Old 03-26-2014, 04:22 PM   #6
tincan1966
tincan1966's Avatar
Also replacing the forward crossmember(under the radiator) would hlp. Looks like the upper passenger side hole for the bumper is missing as well.
Old 03-26-2014, 05:45 PM   #7
Roll'nSlo
Roll'nSlo's Avatar
I'm working on replacing that crossmember, I just want to straighten the frame to the correct position. I'm having trouble finding that crossmember. I have a '78(I think) frame that I'm going to steal it from. I know it's diff but considering my rad bolts to the rad support I figured I would be ok. All the bolt holes are there for the bumper, guess the way I took the pic it's hard to see.
Old 03-26-2014, 05:57 PM   #8
aggie91
I'm just glad to be here!
aggie91's Avatar
That crossmember is different on the '73-'87 trucks. Event he 67-72 trucks are different. If you are using the stock style radiator, there are support brakets on that front crossmember too...
From the picture, you are also missing the passenger side core support mount bracket on the frame.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-26-2014, 07:09 PM   #9
Roll'nSlo
Roll'nSlo's Avatar
I am missing that piece as well but I already have another one.
I saw the difference in the crossmembers. So I'm guessing that just bolting it to the rad support is not good enough?? I'm going with the stock style radiator.
Old 03-27-2014, 12:27 AM   #10
Captainfab
60-66 Nut
The stock/oroginal style radiator does not have any provisions to bolt it to the radiator support. They sit in rubber lined saddles that are riveted to the radiator crossmember, The top is held secure with a rubber lined bracket that bolts to the radiator support along with the lower hood latch. Bolting in the correct crossmember will automatically set your frame wirth. I may have one of those crossmembers. I will take a look tomorrow.
Old 03-27-2014, 08:15 AM   #11
1963c-10
1963c-10's Avatar
I have both of those on a parts frame if you can't find them PM me.
Old 03-27-2014, 08:29 AM   #12
Roll'nSlo
Roll'nSlo's Avatar
Hey Capt, while you're digging around do you mind looking for the upper mount too?? I assumed the radiator bolted to the radiator support because that's how it was when I got it and my '63 had it bolted to the radiator support as well. Thanks
Old 03-27-2014, 09:02 AM   #13
1963c-10
1963c-10's Avatar
The radiator support needs the two forward frame mounts that bolt on the outside of the frame. The radiator sits on a crossmember inside the frame...the two parts you need. I have seen some of the earlier trucks (60-62) that had radiators that bolted to the radiator supports.
Old 03-27-2014, 09:04 AM   #14
1963c-10
1963c-10's Avatar
Heres a pic of the ones I have....the pass side and center crossmember look to be ok, but I will take a better look tonight. If you look at the inside crossmember, you'll see two holes around a foot or so apart....there are two lower radiator mounts that will bolt there and hold the bottom of the radiator. The two supports outside of the frame is where the radiator support will bolt on. This is a parts frame....I only need from the front crossmember back for my trailer project.
Old 03-27-2014, 10:30 AM   #15
Roll'nSlo
Roll'nSlo's Avatar
Looks good from the pic. Just let me know please. Appreciate all the help from everyone.
Old 03-27-2014, 11:04 AM   #16
1963c-10
1963c-10's Avatar
I'll know tonight when I get home. Do you need the pass side frame horn also? Or just the pass side radiator support and the inner radiator crossmember?
Old 03-27-2014, 11:59 AM   #17
Roll'nSlo
Roll'nSlo's Avatar
I just need the radiator support, inner crossmember and the upper radiator support if anyone has one.
Old 03-27-2014, 12:03 PM   #18
1963c-10
1963c-10's Avatar
for v8 or 6cyl?....the upper radiator supports are different.
Old 03-27-2014, 12:12 PM   #19
Roll'nSlo
Roll'nSlo's Avatar
It came with a 6, I'm putting a 489 in it. That's the little support that uses the same bolts as the hood latch right?
Old 03-27-2014, 01:16 PM   #20
1963c-10
1963c-10's Avatar
Yes, but the v8 mount is different. The 6cyl mount is straight and the v8 mount comes up 90* to compensate for the larger radiator. I have a pic somewhere for reference.
These are pics of a members truck...hope rich doesn't mind. Heres the two different mounts. You use the same bolts and mounting locations and rubbers.
Old 03-27-2014, 01:42 PM   #21
Roll'nSlo
Roll'nSlo's Avatar
Ahh ok. Going to go with the V8 style. I have to replace the radiator anyways. Do you have that 1?
Old 03-27-2014, 02:00 PM   #22
1963c-10
1963c-10's Avatar
No, but they pop up in the forum classifieds all the time. Normally around $20 or so.
Old 03-27-2014, 04:09 PM   #23
Roll'nSlo
Roll'nSlo's Avatar
Ok. Thanks found one for $5 plus shipping if he still has it
Old 03-27-2014, 04:26 PM   #24
1963c-10
1963c-10's Avatar
Nice price for the upper support!!
