03-30-2014, 09:44 AM | #1 |
1972 GMC 2500 "Part out"
1972 GMC 2500 Big Block Custom Camper / Cheyenne
Going to be breaking this one down, keeping most BB items. I do have a day job and its still quite cold here so I will be at this as I can. All items are as is. PayPal or USPS money orders. First Ill take it gets it. Shipping extra. Items not listed just ask ! Bare Cab and Doors - $300 Local only ! Complete front clip/doghouse - $200 Local only ! Big Block PS remoter reservoir - $35 Big Block Pass side heat shield w screws - $40 Big Block A/t Shift linkage and bracket -- $75 Big Block 4 core radiator hold downs Upper and Lower -- $30 Big Block Fan Shroud --has cut out on bottom $50 Grill, inner and outer with headlight buckets and bezels (complete) - $100 Grille brace -- $10 Hood latch, pin and latch plate (attaches to hood) -- $15 Core support to fender brace pair -- $10 Front bumper brackets -- $30 Seat belts - ok drivers - $35 Steering wheel (67-68) -- $75 Throttle cable, bracket and th400 kickdown switch -- $75 Heater components --Interior side. $30 Sun visors - Nice stitching $35 Dome light and harness -- $5 washer switch and knob -- $5 Headlight Switch and knob -- $5 Saddle fuel tank selector $20 Taillight - reverse housings -- $10 EBrake - $40 Brake booster/proportioning valve/brackets -- $100 Gauge cluster $50 Ashtray $15 Thx, D'
1967 C10 SWB Owner - Rustbelt Restorations |
03-30-2014, 09:52 AM | #2 |
Vintage 4x4s
Re: 1972 GMC 2500 "Part out"
Will you sell any of the cab roof marker lights?
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
03-30-2014, 09:56 AM | #3 |
Sorry but I already pulled them for my use on my 68 C30.
03-30-2014, 09:53 AM | #4 |
Pics 2
03-30-2014, 09:56 AM | #5 |
Hi Dave.
What do you need for the mirrors ? Any pics of the saddle tank selector ? Thanks
Tom 71 K2500 71 K5 Jimmy |
03-30-2014, 10:28 AM | #6 |
Mirror heads are nice other than flaky paint over the stainless, the ps tripod is stainless the ds is steel. Id do $60 shipped for both mirrors and the selector valve.
03-30-2014, 11:48 AM | #7 | |
Thanks for the pics Dave.
03-30-2014, 10:04 AM | #8 |
Interested in the hub caps (can't tell are they chevy or gmc?) a picture of them would be great.
The dash pad (any cracks or damage?) Antenna with hardware. Original and fixed mast or telescoping? Please let me know what you would like for these items as well Thanks Brian |
03-30-2014, 10:35 AM | #9 | |
Antenna is a solid mast but has been modified, $5 Dash Pad would make a nice patina driver, no curling but does have pressure cracks. $40
03-30-2014, 10:56 AM | #10 |
Roadtrip!
In line for the 2 chevy hubcaps
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
03-30-2014, 11:00 AM | #11 |
Carpe manana
In line for the dash pad...
Are the door latches in decent shape and available? Would consider the door regulators and rear view mirror as well. Thanks
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 03-30-2014 at 11:04 AM. Reason: added rear mirror |
03-30-2014, 11:15 AM | #12 | |
I just found another wall hanger in the garage, same condition. All 3 $45 shipped.
Door latch remotes, DS not 72 and loose, Pass side is 72 correct and solid, good return spring. Window regulator on Pass side 72 correct and rolls up / down nicely. Rear view mirror, is a repo but very good shape.
03-30-2014, 11:20 AM | #13 |
Carpe manana
Thanks - sounds like RH pass door parts are in decent shape - what do you need for the latch and window regulator shipped to 59901? Will pass on LH parts as sound so-so and the mirror. Thanks, Pete
03-30-2014, 06:43 PM | #14 |
I also pulled the pass side window regulator, it is a 72 and functions properly. Add $25 if you want it too.
03-30-2014, 08:04 PM | #15 | |
Carpe manana
03-30-2014, 08:17 PM | #16 | |
View Post Thanks - sounds like RH pass door parts are in decent shape - what do you need for the latch and window regulator shipped to 59901? Will pass on LH parts as sound so-so and the mirror. Thanks, Pete Pass side door latch and Pass side window regulator and pass side latch remote (needed ?) $65 shipped for all 3 items. So yes, I have the 72 correct pass side items as listed above and the drivers side window regulator. The rollers are firm on the studs, 1 roller does have a flat spot.
03-30-2014, 11:21 AM | #17 |
I'll take the thre chevy caps. I would like the dash pad as well but do you have an appropriate box for it? I'm not sure if it fits those triangular boxes?
Feel free to PM to work out the details. Thanks Brian |
03-30-2014, 11:29 AM | #18 | |
Yes I will have proper box and packaging for the dash pad. I will have to ship the caps and pad separately. $45 shipped for the caps, $65 shipped for dash pad. Total - $110
03-30-2014, 11:42 AM | #19 |
03-30-2014, 11:31 AM | #20 |
Any pics of the fender emblems?
03-30-2014, 11:41 AM | #21 | |
Not great, 1 missing the inlay. All studs intact. $15 shipped for pair.
03-30-2014, 11:29 AM | #22 |
HI ! I am interested in the power steering mounting brackets from the big block let me k now the price thanks
03-30-2014, 11:31 AM | #23 |
that is the power steering pump brackets 2 pieces
03-30-2014, 11:56 AM | #24 |
are you going to sell the 4 core radiator , or keeping it with big block stuff
03-30-2014, 12:00 PM | #25 |
Yes its available, have yet to determine its condition. Ill be heading out in a bit to gather up some items and Ill take another look for you.
