Old 03-30-2014, 10:32 AM   #1
bddcustoms
bddcustoms's Avatar
Powerglide vs. Turbo Hydro Steer Column Question
Hey Board,
My '69 c20 came with three-on-the-tree non-tilt. I've swapped in a "modern" 700r4 (from a 1992 C1500).
I'm looking to source a steering column from the salvage yard. As I'm sorting through salvage options on car-part.com, I'm presented with the option of sourcing auto/tilt columns from trucks running Powerglide trannys, or those running Turbo-Hydro trannys. The results are different, of course.
My question to the board is: "Does it matter that I choose a PG or TH column for my intended application?"
Thanks in advance for the feedback
broke d!@k dog Garage
1969 C20 - Project: "Big Sexy" [http://67-72chevytrucks.com/vboard/s...d.php?t=454894]
2003 'Burban - [Big Pop's daily driver]
1969 350/350 Stingray - [as soon as the economy turns...]
1939 Chevy Roadster Pick Up - Project: "Pre-School" (searching now)
bddcustoms is offline   Reply With Quote
Old 03-30-2014, 11:28 AM   #2
SACRAMENTO 71
SACRAMENTO 71's Avatar
Re: Powerglide vs. Turbo Hydro Steer Column Question
68 C10 SWB W/ 72 FRONT CLIP 343SB TH400
64 C10 SWB 406SB TH400
74 SUBURBAN 454BB TH400
78 K10 SWB 350 TH350 6" ON 35" BFG MUD
71 K5 350 W/ TBI 700R4 6" ON 38" BFG MUD
00 K3500 DRW BIG BLOCK "DRINKING PRBLM"
SACRAMENTO 71 is offline   Reply With Quote
Old 03-30-2014, 12:32 PM   #3
Molberg
Molberg's Avatar
I was going through this same thing before I built my console. The power glide column has a shorter travel radius when trying to shift all the way down into low. Seemed the bottom of the column tube(under hood) had a smaller notch area... Not allowing the inner tube/shift arm to travel enough to catch all the ranges of the tranny. Would likely work... May not be able to shift into low. Shy of modding the opening in outer tube.
-Project Nitemare-
http://67-72chevytrucks.com/vboard/s...d.php?t=607359
Molberg is offline   Reply With Quote
Old 03-30-2014, 06:20 PM   #4
hugger6933
With the exception of having to notch the bottom of the shifter tube the other difference that would cause a kickback for car/part. is the shifter indicator showing L D and the 3 speed showing L2D. I use car/part a lot and they are quirky about those little things but then they are just following the lead of the Hollender book people. Jim
hugger6933 is offline   Reply With Quote
