Bought parts for $290.00
I bought, 2 and 1/2 inch drop spindles, 6 lug rotors, backing plates, calibers, front brakes hoses, rear drums, backing plates, rear brake cylinders, emergency cables, and a chrome alternator for $290.00. They had only 1,000 miles on them. That should keep me busy next winter.
![]() Join Date: Feb 2010
Re: Bought parts for $290.00
Nice!
SCORE! Nice find, now get busy
GOD BLESS AMERICA! |
Nice! Great price !
Nice score! The front spindle and brake set up is worth $600 alone!
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
![]() Join Date: Sep 2011
Good for you!
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
![]() Join Date: May 2010
Nice, Don't forget to post before and after pictures.
It will be a while before I get started. I need 4 inch lower rear springs, and an adjustable track bar, and 18 inch 6 lug wheels, and tires. It may be a year or two. I have the money, but can't see buying the wheels, and tires, because mine are new.
here is the truck
![]() Join Date: Aug 2004
Nice truck!
You can surely use te 15" smothies until you buy bigger wheels, any chance you would be towing? Might go bags then. Rear springs are 100-120\pr and a track bar is around 60.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
I won't be towing. Do you think my 15 inch wheels will work with front disk brakes.
They look like chromed aftermarket wheels, I would think they would. If they were stock wheels from the early 70's then I would bet not. Reach a tape in behind and get you a ball park idea of the back spacing. That will tell you for sure.
![]() Join Date: Mar 2013
SUPER SCORE on those parts!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
I would put it all together off of the truck and than put it on the wheel to make sure. I had a set of drop spindles that did not work with my aftermarket 15" wheels.
#15 |
The rotors, calipers, and spindles are all together. I will take a wheel off , and see if it will work. I am trying to figure a way to get the chrome cap off the chrome wheel without scratching them.
#16 |
I think they have plastic pry bars at auto parts stores. Om mine there is usually a small gap along the edge because the caps don't fit perfectly.
