Old 04-01-2014, 03:40 PM   #1
keh27
keh27's Avatar
front sway bar woe's
This is my cpp front sway bar, what am I doing wrong here, I see no way for this to work at all. Someone tell me what how the heck this is suppose to work. thanks
keh27 is offline   Reply With Quote
Old 04-01-2014, 04:11 PM   #2
ulakovic22
Re: front sway bar woe's
Did the low profile mounts come with the CPP bar or are those something you had before? I would lower the vehicle so it's sitting on the ground and see how much that helps and then it's possible that you might end up mounting the bushings/mount directly to the frame. From what I've read it's actually pretty common.
If the whole setup came from CPP then I would put it on the ground and if that didn't work, contact CPP, I believe that Jeff is still active on here.
Anthony
'67 Shortstep (555/T56)
'67 Parts Truck (TBA)
ulakovic22 is offline   Reply With Quote
Old 04-01-2014, 04:18 PM   #3
keh27
keh27's Avatar
Yes its all Cpp, Thanks for the response, Its no closer on the ground, but again the motor is out of it. Maybe I'm wrong but it shouldn't matter,if the links are straight now they won't be then. If it doesn't fit the factory holes, I will get a factory type bar, That's what I should have done anyways, haha
Old 04-01-2014, 04:34 PM   #4
keh27
keh27's Avatar
Jeff's accounts shows to be Account Suspended.. If he's around I would like him to see this, before I have to get on the dang phone with them, not the best customer service from at least one of them a few weeks back.
Old 04-01-2014, 06:49 PM   #5
cdowns
cdowns's Avatar
move the frame mounted pieces so they line up drill holes and bolt it up
sometimes fabrication is necessary
Old 04-01-2014, 09:17 PM   #6
keh27
keh27's Avatar
Thanks for the response, I know the rear one will have to drilled and fabricated, but I would think the front one would bolt to factory spec. but then again nothing surprises me about this company now.
Old 04-01-2014, 09:11 PM   #7
michael bustamante
michael bustamante's Avatar
Are those the factory frame mounts or from cpp? It looks like those need to be moved to provide for the sway bar links being used in place of the factory horseshoe shaped mount
1967custom
michael bustamante is offline   Reply With Quote
Old 04-02-2014, 10:42 AM   #8
ulakovic22
Why are you not interested in moving the sway bar back?
Anthony
Old 04-02-2014, 12:00 PM   #9
keh27
keh27's Avatar
I have already removed the rivet, and I think I rather have a stock appearing one after looking at it.
Old 04-02-2014, 06:08 PM   #10
knomadd
knomadd's Avatar
You removed the rivet? I don't think you needed to remove the rivet. Mine had holes behind the rivet for the sway bar mount. I think you may have mounted your bracket too far forward. Here's mine. You can just barely see the rivet head in front of the bracket. If I remember correctly, I didn't drill the front hole, only the back one, and the front hole was slotted.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 04-02-2014, 07:16 PM   #11
keh27
keh27's Avatar
Thanks for the pics..... I'm pretty sure the factory one went to the hole in toward the rear of the slotted hole and then the rivet that holds the front cross member. If I put it in the slotted hole it would be further away. but thanks for the pics, nice truck man
Old 04-03-2014, 09:59 AM   #12
ulakovic22
Those are my thoughts as well. The factory mounting bracket used the crossmember rivet. I have a factory sway bar and ECE lowered frame mounts so I will check tonight and see how they line up. I have not mounted mine yet, but I'll give it a shot to see where the stock bar will hit the frame.
Anthony
Old 04-03-2014, 09:49 AM   #13
knomadd
knomadd's Avatar
Hmmm, interesting... Sorry it didn't help you. It does look like your brackets could be moved back some though. I believe mine are, but I'm only looking at how close the short side of the bracket is to the bend in the frame. It looks like mine is closer to that bend than yours. That might be why yours isn't lining up? If you go with a factory style sway bar, it might have the same problem. I don't know since I'm not using a CPP bar, and I don't have a factory bar either. If the factory bar isn't longer, you'll probably end up with the same problem. Just a thought. Good Luck!
-Duane
Old 04-03-2014, 02:21 PM   #14
keh27
keh27's Avatar
No thanks for the response I appreciate it. I think the Cpp bar is one fits all and none. haha
Old 04-03-2014, 05:48 PM   #15
lolife99
67-72 parts collector,…
lolife99's Avatar
Your CPP bar should mounted to the front mount first.
The Addco brand sway bars come with an angle iron bracket that bolts to the front of stock C10 a-arms.
The end links attach to the top of that bracket,... not thru the top of the a-arm.
Your bar needs to move forward.
Look here:
http://67-72chevytrucks.com/vboard/s...d.php?t=322228
Keith
Convert to disc brakes.
Old 04-03-2014, 09:09 PM   #16
keh27
keh27's Avatar
Thanks for all the great info..... that's why I love this forum. Thanks everyone
Old 04-03-2014, 09:25 PM   #17
keh27
keh27's Avatar
Look here:
Thanks Keith, but I like this look better , ha-ha. But really I think its a cleaner look and its the right way.
