Old 04-03-2014, 08:19 PM   #1
1966
Found the leak source in my 205 transfer case, question
found my leak, is that the speedo cable?
1966 is offline   Reply With Quote
Old 04-03-2014, 08:50 PM   #2
Avitech
Avitech's Avatar
Re: Found the leak source in my 205 transfer case, question
yes it is.
1990 Suburban Silverado
350, SM465 and 35" tires
Avitech is offline   Reply With Quote
Old 04-03-2014, 08:51 PM   #3
kwmech
Yup, unscrew the cable, push to the side, get a socket that fits the larger nut 1-1/16'' (i think) unscrew that and remove the nut and driven gear. Go to local transmission shop and tell them you need a seal that fits inside there. I think there is room for you to double them up
Old 04-03-2014, 08:53 PM   #4
1966
thanks guys. i've done some reading that gear oil is ideal, but obviously PO had tranny fluid in there. keep it the same?
Old 04-03-2014, 09:02 PM   #5
kwmech
If the 205 is bolted to an automatic transmission, then you may have a problem. Pull the filler plug and see how much fluid comes out. If it is overfull, you will have to pull the case out of the truck and replace the seals in the adapter housing. Transfer case should take 80/90 wt gear oil
Old 04-03-2014, 09:03 PM   #6
1966
yup it's an automatic
Old 04-03-2014, 09:15 PM   #7
kwmech
Have fun, the transfer case weighs 156 lbs
