Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 04-04-2014, 07:16 PM   #1
GMC Sub4x4
GMC Sub4x4's Avatar
LED Tail lights $30 in 30 Minutes
I decided I wanted LED Tail lights on my 61 Suburban. After looking everywhere I could not find anything. I came up with the following plan to make my own. I started with Semi trailer LED sealed lights.
I started by cutting the red lens off of the LED lights.
GMC Sub4x4 is offline   Reply With Quote
Old 04-04-2014, 07:22 PM   #2
GMC Sub4x4
GMC Sub4x4's Avatar
Re: LED Tail lights $30 in 30 Minutes
Next I determined they were to thick to fit behind the stock lens. I did not want in any way to modify or destroy the stock aluminum bulb/light housing. So I used a handsaw to cut the plastic surrounding the plug on the back off. I then used a die grinder to grind the brass electrical terminals flush with the back plastic. Then I soldered wires on to the brass terminals.
Old 04-04-2014, 07:26 PM   #3
GMC Sub4x4
GMC Sub4x4's Avatar
After that I used simple electrical tape to insulate the electrical connections from the light housing. The light fits snug in the housing, but I used double sided foam tape to keep it from rattling around behind the stock lens.
Old 04-04-2014, 07:36 PM   #4
GMC Sub4x4
GMC Sub4x4's Avatar
Final Product. I only spent about $30 on the two LED lights and after hours of planning in my head, it only took about 30 minutes to actually make them fit.
Old 04-04-2014, 10:12 PM   #5
kerber63
kerber63's Avatar
Great idea, looks slick. Any issues with blinkers/brake lights?
1963 C10 short-wide
Turbocharged 454, T56, 4.11 posi
http://67-72chevytrucks.com/vboard/s...d.php?t=605408
1963 C10 suburban
Unknown, unknown, 3.73 open
http://67-72chevytrucks.com/vboard/s...d.php?t=622037
kerber63 is offline   Reply With Quote
Old 04-04-2014, 10:22 PM   #6
MusicMan70
MusicMan70's Avatar
This is so o great of you to share this idea. Big thumbs up! Thanks.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 04-04-2014, 10:45 PM   #7
463
463's Avatar
very nice thank you for the Post.
Trueman
463 is offline   Reply With Quote
Old 04-04-2014, 11:24 PM   #8
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Great job !
Ive thought about doing this ever since LEDS were introduced to the commercial industry in the mid 90's ....
Thanks for sharing with the group
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 04-04-2014, 11:36 PM   #9
63burban
Chevy addict
I use 57 Chevy passenger car leds for this type of thing, they are real flat.
Installed them in my buddy's 57 Tbird, they work great. A little more expensive but more leds.
63burban is offline   Reply With Quote
Old 04-05-2014, 11:09 AM   #10
chakah
chakah's Avatar
came out great, nice job
"El Jerry"
'03 3500 Duramax dually
'96 1500 ext. cab Chevy
'66 swb C-10
'63 Panel
'60 VW vert
'56 VW vert
chakah is offline   Reply With Quote
Old 04-05-2014, 11:26 AM   #11
hopped up
hopped up's Avatar
Looks great! ESP since you kept the stock tail lights. Thanks for the info
hopped up is offline   Reply With Quote
Old 04-05-2014, 09:16 PM   #12
69 chevy 1
69 chevy 1's Avatar
very cool ideal looks good thanks for the post
69 chevy 1 is offline   Reply With Quote
Old 01-03-2015, 11:53 AM   #13
piratexpress1369a
piratexpress1369a's Avatar
great post i had read this when you had first posted and i had bookmarked it but my laptop crashed and i lost it ...so did you need to modify the flashers
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 01-03-2015, 05:14 PM   #14
65sub
65sub's Avatar
great idea. I'm going to modify mine thanks.
65sub is offline   Reply With Quote
Old 01-06-2015, 05:35 PM   #15
Free Candy Inside
I did the same thing to mine except I spray painted the housing chrome and added a few pieces of reflector tape just because. I used an led panel that was suppose to be for a harley tail light. I did however put a screw into the housing. I had a spare set of housings. Here's how mine looked as tail lights
Free Candy Inside is offline   Reply With Quote
Old 01-07-2015, 11:03 AM   #16
piratexpress1369a
free candy inside did you have to add a resistor to slow down the flasher
63
Old 01-07-2015, 11:40 AM   #17
Free Candy Inside
Nope. It worked like it was suppose to. However, I am running a wiring harness from a 95 Chevy. My drivetrain is a TBI 350 so I used the complete harness including the headlight switch, turn signal flasher, etc. I just wired in the turn signal wires from the 95 harness into the turn signal switch from the 63. I doubt that has any effect though.
Old 01-07-2015, 11:13 AM   #18
67swb72klb
67swb72klb's Avatar
great idea
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 01-08-2015, 10:43 AM   #19
piratexpress1369a
ok thanks
63
