Remove front bolt from front leaf spring 67-72
Hi everyone. I'm trying to get the front bolt out of my front leaf spring on my 69 4x4. I can get the nut off and the bolt has moved a little, but that thing will just not come out. Is there some sort of trick to getting these things out? Any tips would be greatly appreciated. Thanks, Brian
Re: Remove front bolt from front leaf spring 67-72
it may be rusted to the spring eye sleeve. that would probably let it move a little but not allow it to come out. given that you are in michigan, that isnt totally wierd. you may have to get destructive to remove it.
Darn.... That's not what I wanted to hear. Thank you for the reply though.. Does make sense, if there is a sleeve in there, I'm sure the bolt has probably froze to it.
20' Daredevil (Ret)
![]() Join Date: May 2003
Yup, probably rusted. Forgive me for asking, but wanted to make sure you have the axle supported so there's no weight on the bolt.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
Windy Corner of a Dirty Street
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
The weight is off it, so its not binding or anything like that. I really wanted to reuse the bolt and sleeve. If I end up having to cut it, I'd have to end up replacing the bolt, sleeve, and bushings, is that correct? Is the bolt hardware store type item, or special order?
I believe LMC has that sleeve and bushing. Don't think its a auto parts over the counter thing.
if it is rusted enough that you cant get it out, re-use is not that great of an idea anyhow. bushings and new hardware are cheap and not a good place for going low-buck.
![]() Join Date: Jan 2007
Get new parts. Then, heat up the bolt with a small torch to melt the rubber and slide it all out. Once the holt iz out you can ptobanly pry out yhe bushing. Put in new bushings and bolt...you may or may not have to chisel out the sleeve depending on size of replacement bushing.
It will stink like burnt rubber and watch your flame...
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() |
Roto Reuter thats the name...
![]() Join Date: Feb 2010
Need to use a torch to burn up the rubber and/or cut the bolt. Big hammer needed to pound out. Make sure you have plenty of ventilation and mask when burning the rubber bushings. New parts are cheap. I wouldn't plan on reusing anything. I would buy all new hardware. Good luck.
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
Well, thanks everyone. I tried the bfh method extensively. That was a no go. metal cutting blade in the saw did the trick. Probably could reuse the busing. It has replacement nylon's in it. I'll probably replace bushings anyhow. Have to pick up a new bolt and sleeve.
Fastenal has 9/16 hardware.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
