![]() Join Date: Mar 2013
Need a good helper airbag setup for tow/haul
Hey guys, since I raised th front of my c20 2" to level I now get really bad sag in rear when towing rv or boat. I knew this woukd happen and have nk refrets as I love the look of a level unloaded truck.
What I want is a good helper bag setup rated for my truck, to sit on the rear 14 bolt rear, or however they mount. Its an 85 3/4 ton camper special. I'm not Interested in one with a compressor to air up on the go, I can air it up with a small portable compressor ill carry in my truck. Anyone got any advice, pics or links? Thanks! ![]() ![]() ![]() |
Re: Need a good helper airbag setup for tow/haul
Look around http://www.airliftcompany.com/ they have a kit that is just the bags and mounts.Then you can get normal air lines and schrader valves from one of our air ride venders on here.
I have used the 5000lb air lift kit on my 1967 C20. For my truck I had to modify the upper frame bracket. Your truck will be easy just drill a few holes. I have used it flawlessly for 5 years in my work truck used for roofing.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Here is a link http://www.summitracing.com/parts/fi...1985/model/c20
