Old 04-08-2014, 11:20 PM   #1
Iceburgh
Iceburgh's Avatar
Throttle linkage
For you guys that don't have a drive by wire.....
What are you running for linkage that does not bind.
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 04-09-2014, 09:35 AM   #2
Matt Cramer
Re: Throttle linkage
A 3' mountain bike brake cable with a knarp end at the stock '72 gas pedal. Works great and only cost $12. For the mounting end at the firewall, I drilled out the clip on the stock throttle cable.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 04-09-2014, 08:01 PM   #3
trkfrk
trkfrk's Avatar
Do you have any pics? Great idea!
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 04-09-2014, 09:57 AM   #4
littlevictories
I pretty much used the same as ^he did. 70's cable style pedal. I made my stock 2002 throttle cable work instead of a bike cable and a knarp, but I think that is pretty legit way to go about it. My pedal sits up off the floor pretty high, so I may re-do it. My pop say 70's van pedals would work better for the firewall in earlier trucks (66 and earlier)
littlevictories is offline   Reply With Quote
Old 04-09-2014, 11:14 AM   #5
aggie91
I'm just glad to be here!
aggie91's Avatar
I used the factory cable from the donor 2000 model with the stock '82 pedal. Did not have to change anything.
I have the same pedal in my '65, so I will do the same when I put the LS into it.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 04-09-2014, 12:21 PM   #6
wgeyer88
I'm using LS1Nova's idea. check out this post in his build thread.
http://ls1tech.com/forums/16783919-post34.html
Will
1970 CST10 SWB LQ4/4L80E
2004 Silverado (sold)
2007.5 Dodge Ram 2500
wgeyer88 is offline   Reply With Quote
Old 04-09-2014, 03:58 PM   #7
littlevictories
when he says "cable end" i wonder if he means he's using a knarp or crimping some sort of thing on the cable.
Old 04-09-2014, 05:36 PM   #8
wgeyer88
This is a later post in the same build thread.
I would actually encourage anybody to read through the thread, I got some great ideas there.
http://ls1tech.com/forums/16806800-post61.html
Will
Old 04-09-2014, 06:47 PM   #9
Iceburgh
Iceburgh's Avatar
Great ideas
1953 suburban build
Old 04-10-2014, 11:23 AM   #10
Matt Cramer
I'll see if I can get a few.
Matt Cramer
4.8 LS build thread
Old 04-10-2014, 03:57 PM   #11
Billett
Billett's Avatar
Lokar cable and a 72 pedal swap for me
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
