04-09-2014, 08:42 PM | #1 |
33s on a 2wd?
What would it take to run 33s on a 2wd c10?
04-09-2014, 09:56 PM | #2 |
Re: 33s on a 2wd?
With a stock stance they will fit fine. A little tight up front but fine. I ran them on my 69
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
04-09-2014, 10:19 PM | #3 |
Re: 33s on a 2wd?
Thanks that's what I thought, I am picking up a nice longbed and want to run a set of 33-10.50 I have
04-09-2014, 11:18 PM | #4 |
Re: 33s on a 2wd?
Would you be able to run 35s with a 2 in lift on the front?
1971 Chevy C10 Cheyenne (sold for Mazda) 1963 Chevy Corvair Pro-Touring Project 2012 Mazda 3 i Sport sedan http://www.dracoautodesigns.com/ |
04-09-2014, 11:36 PM | #5 |
Re: 33s on a 2wd?
don't know about 35's I ran 33x12.50x15's and it was fine
04-11-2014, 02:52 PM | #6 |
Re: 33s on a 2wd?
I've seen factor 3/4 tons with the same size wheels front and back (33 x 12.50 x 16.5) and apparently they don't rub. I ran 32's in front on my 1 ton and have to "manipulate" the front fender corner on one side slightly.
04-11-2014, 03:05 PM | #7 |
Re: 33s on a 2wd?
I had tall skinny 7.50x16 Lt tires on my 67 2wd when I first got it. No problems but they would rub if you turned the steering all the way. I think they were about 31-32" diameter.
Dane 67 Chevy Fleet 250/4 speed 1/2 ton 68 Chevy 250/4 speed 1/2 ton for parts 49 GMC Grain truck 235 1 1/2 ton 76 Chevy 350/4 speed 1/2 ton |
04-11-2014, 09:31 PM | #8 |
Re: 33s on a 2wd?
Having a ton of caster helps pull the wheel back in the opening to clear the front fender bottom. I have a 3" lift I had 285 75 15 and they rubbed. I kept wearing out the idler arm and upper balljoints. So I switched to 265 75 16 .
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
